Question about Toshiba CX27F60 TV
Flashing power indicator
TV has been working fine, but now seems stuck in some kind of "sleep" mode. When turned on, the power indicator flashes on and off continually, but no picture or audio - just black screen. By toggling the ANT button on the set or the TV/Video button on the remote, I can hear that the set is switching input signals, but still no picture or audio. I've tried switching the set on and off, reconnecting everything, even leaving it on for hours in this current state, but no change. Any help would be appreciated. Thanks.
    Novelist:
    Champion:
  • 236 Answers
Generally a blinking light such as you described indicates a "shut-down" condition which usually means something has shorted. AS our guest said it would take a tech and some trouble shooting to find your problem. Stargazer
Posted on Jan 28, 2007
Sounds like a power supply problem unless there is a short in the deflection circuits causing the power light to flash. I'm afraid it'll take a technican to figure out what is wrong. If it's more than 7 years old, you might consider replacing it.
Won't stay on
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
May 22, 2017 | Sony KDL-52EX701 52 in. LED TV
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Sorry for the repost but i have had trouble responding to your experts for some reason the comment window won't allow me to type from iPad. Anyway, after the hard drive issues which will be solved by the...
Flashing power light indicates that there's a problem with the RAM. You're referring to a Standy by mode when you turned on the computer. If you have a spare ram you can try to use 1 to check if the RAM that you're using is faulty. Mobo is fine dont need to worry about that. No need to remove the CMOS battery. If you know someone who has the same ram or another computer you can try that. Usually it happens to Desktop Computers that monitor was on standby mode when they have a bad ram.
Thanks for using Fixya.
Feb 11, 2011 | Gateway 4542GP Notebook
Plasma tv picture not coming on and power light flashing
Yes, you have power supply issue.
the power on circuit is malfunctioning and the flashes is the indication that the voltage levels for the power on regulation is not correct therefore shut down to protect the circuit from further damage. You TV unit needs servicing by an plasma TV specialist.
Also check to see if you do not have the TV in sleep or hibernation mode.
Apr 22, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Sep 05, 2009 | Televison & Video
The power indication display is flashing with all colors visible.
The flashing will come on if the chair is in neutral or if the charger is still plugged in when you turn it on. Place the chair in neutral (freewheel) by shifting the levers out, then place firmly back into drive.
Unplug from the charger and it should fire up. Sometimes, the chair will also go into "sleep mode".
Check your owners manual for this. Note, some have sleep mode potential but it's not in the manual, and if someone inadvertantly hits the right series of motions with the joystick, you can inadvertantly put it to sleep. Try turning the chair off, wait three seconds and power back up, then immediately press the "horn" button. This wakes up most of them. Others you need to power off, turn back on and then move the joystick forward, backward then forward again.
Good luck
Jun 23, 2009 | Electric Mobility Power Electric Scooter...
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
TV will not turn on model aquos LC-46X20 Went away for a long weekend, did not turn power off left TV on stand by. Came back and power LED on front of TV is flashing and will not show any form of piture...
hello. here is something you can try , unplug the set and let it set. for about 10 mins. then plug it back and try tpo turn it on. hope this help's you. let me know "GOOD LUCK"
Jul 27, 2008 | Sharp Televison & Video
Stuck in sleep mode w/black screen
If possible, try a friends monitor first. If it works, you can then change the sleep mode setting so that it won't come on again. If the other monitor does not work, the video card is probably defective.
Oct 26, 2007 | Computers & Internet
Old Samsung portable TV
Obviously the problem is with the SMPS unit, could be a faulty switching transistor.
Oct 11, 2007 | Samsung TXN2726 27" TV
Televison & Video Logo
105 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
