Question about Vacuums
Dyson dc7 quits after a few minutes running; runs again after an hour or two of rest. Filters are clean, beater bar is clean, can't tell about the airways because I can't see how to get to them.
  • 107 Answers
Check the ducts with a small object(screw or something with a little weight)down the ducts to verify they are clean. Also check the Ubend on the back bottom of the unit. Looks just like a U. Remove with a turn of the tab by a screwdriver or quarter. Let me know if the issues still exists.
Posted on Dec 08, 2008
Dyson canister DC39 - beater bar won't spin once it touches the floor
Some models have the beater bar driven by the airflow from the vacuum rather than a small motor. It takes a lot of suction to turn the brush roll. Make sure there are no restrictions which will reduce the airflow and suction. Replacing the filters may help if the vacuum motor still has adequate suction.
Sep 17, 2017 | Dyson Vacuums
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
Dyson DC17 Beater Bar Won't Work. The beater bar starting to make a very loud grating sound then stopped working. I cleaned the entire area (there are no obstructions) and the belt is OK. The beater...
I'm sorry to hear that you're having difficulties with your DC17's brushbar. If it appears to have jammed completely, it's probably best if you get in touch with us directly so we can help - please call free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum will run for 5 minutes and shut off,
Your Dyson is designed to cut out if it becomes overheated, and it then takes about half an hour to cool down properly. If you don't resolve the problem, it will soon cutout again. Clogeed filters or other blockages are the usual cause of cutting out, but there are others, for example, incorrectly fitting valves, or broken belt. You need to do more cleaning. Follow the step by step instructions for your model, which can be found here.
http://www.dyson.co.uk/support/help.asp?article=51&product=DC07-ANIMAL
You will be following a path for solving cutting out when you are using the machine, and I would be surprised if you can't fix yours.
Jul 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum shuts off after short run time . it will turn back on after about 5 minutes but then dies again
This is overheating and tripping the thermal cut-out on the motor.
You need to strip off all filters, clean or replace them (if caked solid). Very often panel filters can be cleaned by knocking them on an outside wall, then a good blow to clear loose dust.
Dyson's often overheat if the filters are not cleaned.
Make sure belts are in good condition, and beater brushes only contact the floor slightly. You need to adjust this hight for different floor surfaces - or it will overheat on thick carpet.
Sep 22, 2009 | Vacuums
Ratchet noise, beater will not turn, belt not broken, in carpet mode the Dyson d07 makes huge ratchet noise and the belt will not turn the beater brush.
Ok, so I had the same ratching noise and took the advice of many sites directing me to clean the brush. But like most I cleaned the brush and the noise continues and the brush does not spin. Reluctant to take it to get serviced I dug a little deeper and now it works just fine. This is what you need to do as removing any hair from just the brush part will not be enough.
Remove the entire brush bar from the bottom of the Dyson, this means pulling the bar out of the drive belt. This is not to difficult just use a little muscle as the belt will stretch. Once the bar is out grasp hold of the two plastic end caps on the brush bar which the brush bar actual spins in. These two caps are connected by a slim metal rod which runs through the brush bar. Place one hand on each side and begin to twist and pull until one of the caps comes off. Once the cap is off of the one side you can pull the other cap from the other side through the brush bar as this cap will be the one attached to the slim bar I mentioned above. If like mine you will see a ton of hair wrapped around these caps and inside the ends of the brush bar. Clean them out as best as possible.
After you clean it out, run the cap with the rod back through the brush bar, attach the other cap and twist and push together. Make sure the caps lineup which each other just like they were when you pulled it out. You'll notice how much more freely the brush bar spins between the two caps then before you cleaned it. Now, pull on the drive belt and feed the brush bar back through and attach as it was to begin with. This did the trick for me.
Apr 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
60 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
