Larry, All plugs listed below should work in your 5.5 B&S Quantum engine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Genuine Briggs & Stratton Part 802592
Replaces Champion J19LM or RJ19LM
Also is the same as NGK B2LM or BR2LM
Also is the same as Autolite 458, 308.
Briggs & Stratton new number for 802592 is now 796112
I believe the condition your describing is called "hunting" this sometimes happens when engine has a problem with it's air/fuel mix usually due to a carb problem
id start by cleaning out the fuel tank and filters and then moving on to the carb
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
if the engine is a briggs and Stratton then check the valve clearance as B&S engines have a history of the valve stems stretching early in use and when hot hold the valve partially open until cooled down
In Briggs & Stratton motors used in mowers or similar equipment the spark is generated by a magneto : a magnet situated on the flywheel passes in front of the ignition coil and generates the spark.
If the engine is backfiring then the flywheel is incorrectly positioned - take it our and rotate it for one bolt
try some wd40 on the shaft the gear rides on. work the gear by hand alittle it may just be stuck. usually if you dont have the power to spin the gear up the starter wont run at all
Sabre riding mower. Runs, back fires, almost dies,still runs. Back fires again, then dies and can not restart Please HELP!!!!!! Mower model #1438 14.5/38. Engine Briggs and Stratton, Model #287707, 14.5hp, OHV.
