Question about Plumbing
Repair cartridge in Moen Monticello single handle lavatory faucet
Slow leak on cold water side of moen single handle bathroom basin faucet
Trying to determine cause
Trying to disassemble faucet for inspection
Can't remove retaining ring (apparently most simply screw off). Turning plastic ring with pliers not successful (spins round and round)
A small hole in the rear of the retaining ring suggests the possibility that a cir (spring) clip may have to be removed first. Can't determine how of if there is a clip to be removed.
Thanks in advance,
Dale
  • 7 more comments
  • Anonymous Jan 03, 2009
    anybody?
  • Anonymous Mar 13, 2014
    Slow leak at base of lever handle when faucet is turned on. Does not leak when faucet is not turned on. Do I need to replace the cartridge? I don't know exactly which faucet model it is.
  • Anonymous Mar 20, 2014
    how to remove and replace cartridge on a Milano single handle faucet
    removing the cartridge from faucet
  • Anonymous Mar 23, 2014
    faucet leaks out of the middle hole under the sink just above the p trap
  • Anonymous Mar 24, 2014
    removed the screw and turned the ball counterclockwise. Nothing. videos all show that it should pop off and expose the rings. Help
  • Anonymous Mar 27, 2014
    the bell under the turn handle won't come off. tried and tried to turn it but wont budge suggestions?
  • Anonymous Mar 29, 2014
    No manual and retailer no longer supporting this product. How do I repair the leak. I can't find a manual on-line either. I've removed the handle but not sure what to do next.
    Thanks
  • Anonymous Mar 30, 2014
    Brand new faucet. Everything is fine except the hot water handle. It leaks through the handle and wont turn off. Spins all the way around.
    Problem Solver:
  • 9 Answers
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Have a moen brantford bathroom faucet. One handle has become very hard to turn. The hot water side turns fine, but you have to use muscle to turn on the cold. Does the handle need to be replaced or the...
    It usually takes a special tool to remove a Moen cartridge. Just getting the handle off can be tough. How long have you had this unit? maybe it would be cheaper just to replace the whole thing. My last Moen lasted a good twenty years, still working good, but finally starting to corrode. Good product.
    Nov 30, 2013 | Moen 6610 Brantford Two Handle Lavatory...
    Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
    Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
    Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
    No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
    Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
    Soak the dirty cartridge in vinegar for four hours and replace.
    If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
    Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
    My classmate
    Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
    Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Need to change washer faucet
    Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
    Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
    Leaky moen 2 handle faucet
    if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
    Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
    Trying to put new cartridge in my moen bathroom faucet and i don't know how to do it. It is a teardrop one handle faucet. Please help a single woman not have to call a plumber!!!
    shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
    Apr 25, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    How do I fix a dripping MOEN T4572 lavatory faucet
    If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
    No charge.
    Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
    Need to replace handle adapter kit on a Moen monticello two handle lavatory faucet
    Lowes might carry them but i know a plumbing supply house does for sure. Take center caps off hot and cold handls, then screws everything else should pull right off.
    Sep 10, 2009 | Moen & Monticello& Two Handle Lavatory...
    Plumbing Logo
    1,553 people viewed this question
    Top Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
