Question about Hoover U5106-900 Breathe Easy Bagged Upright Vacuum
Hoover U5106-900 Parts///I need motor brushers
    Scholar:
  • 131 Answers
Http://www.kleansweep.com/hoover8.htm
try this site,they have a complete list of common hoover motor brushes(with pictures)hope this helps
Posted on Nov 30, 2008
Is there suposse to be two belts on this vacuum
yes there are two belts this link below is the manual will give you full instructions on page 11/12.
http://hoover.com/file/640/
Feb 27, 2014 | Hoover UH70040W Bagless Upright Cyclonic...
Brushes won't turn
The brushes are powered by air suction from the motor. At the heart of this complicated system are roller bearings. When one fails the system fails. This is not one of the parts that Hoover thinks is needed on it's parts site so I've haven't found a way to repair this.
Jun 28, 2011 | Hoover F7452-900 SteamVac Upright Vacuum
Motor making a noise. I have a Hoover Canister S3573-016
A motor noise indicate a loosen parts of the motor. The bushing, brushes also a lack of oil or grease will cause a noisy motor.
Check motor and apply oil or grease, inspect also the bushing, brushes.
Good luck.
Jun 25, 2011 | Hoover Vacuums
How do i fit new carbon brushers to dyson dc14
It will be a pointless exercise Ron. By the time the brushes on a YDK DC14 motor have gone, so has the armature. You need to replace the motor. You can get a new motor here: Dyson DC14 new motor.
Also, be sure you change the filters; one of which is washable.
Nov 12, 2010 | Dyson DC14 All floors Bagless Upright...
Why brusher not working
try to wheel on its axle
maybe it is stuck
dont be afraid to use force on it
May 28, 2010 | Hoover F5906-900 Upright Steam Vacuum
I need to switch on my thermal protector on my hoover
FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally there are either screws, clips or levers that would remove the bottom plate or lid that does not work then the top cover will come off and that will expose the belt of the hoover from there u can continue further by opening the locks with proper screwdriver.and then the motor can be seen.
Nov 17, 2008 | Hoover Vacuums
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover U5106-900 Breathe Easy Bagged Upright Vacuum Logo
128 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
