Question about E-Machines M6811 Notebook
Slow operation The lapTOP OFTEN TAKES 10 MINUTES TO REBOOT, LOADING AN APPLICATION CAN ALSO TAKE SEVERAL MINUTES
  • donn_alexand Nov 30, 2008
    Sorry, my description of the problem was too brief. We had already checked startup tasks... Nothing beyond the usual windows stuff.
Try a clean boot, and then a malware scan
free download below
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
Posted on Dec 29, 2008
    Genius:
  • E-Machines Master
  • 1,250 Answers
Remove unnecessary programs from the startup
Posted on Nov 27, 2008
Why is my words with friends not loading
maybe your wi fi is slow and that way it takes that long to load
Sep 14, 2014 | Apple Ipad I-pad
My nec versa e2000 always reboot after power up for a few minutes
It would seem that a driver may be the cause which is loading during startup.
Suggest booting into safe mode by pressing F8 before laptop boots into Windows and then use msconfig to select the drivers to load at boot time.
Keep eliminating drivers until you locate the one causing the problem and then remove and check for a later verison of the driver.
Mar 25, 2014 | Computers & Internet
Lenovo E430 is very slow
Run Disk Cleanup:-
Efficiency of laptop decreases when it contains too many junk files. To clean junk content from your system follow the steps below:
- Click Start
- Type Disk Cleanup
- Press Enter
- Select the drive which you wish to clean
- Click OK
Fix Registry Errors:-
Mostly laptop runs slow issue occurs due to broken Windows registry entries. Fixing registry will help you to boost up your laptop. You need to download and install a Registry Cleaner program to fix corrupt or broken registry entries. To download a reliable registry cleaner, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends. After downloading run all of its tools one by one except Internet Optimizer, to clean all the junks and registry errors from your computer.
Nov 07, 2013 | Lenovo ThinkPad Edge E430 Laptop Computer
My dell pc laptop seems to lockup when scrolling, why?
You might have some processes that are in auto start mode that come pre installed on the machine like DellMedia Direct or something along those lines. Use Windowns SysInternals utility DebugView. Using this utility you can view any debug output generated by any application (including Windows itself) running on your system. Very useful. Use the SysInternals tool called AutoRuns to see what is auto starting. When you see what the application is that is slowing you down simply uncheck it and reboot.
Feb 15, 2012 | Dell Computers & Internet
My dell Studio laptop takes too long to wake from sleep mode and the monitor just flickers when i try to switch on
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer.
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 13, 2011 | Dell Studio 1537 Laptop
My Vaio is very very slow in starting up after about 5 minutes a window comes up " the application (ISBMgr.exe) can not be initialized 0x0000022", click ok" - after a couple of minutes the same message...
Reinstall your operating system and you will get rid of all these unpleasant malware. Another short term sollution is to enter msconfig and uncheck the programs that are starting with your O.S. To do this press Win Key + R and then type msconfig. Go to the Startup tab and uncheck the programs that aren't necessary. Leave only the O.S. components. But for a safer solution, reinstall your operating system. From what you are saying you could have some viruses and malaware. If you need further assistance, just leave a comment. P.S. Here is a tips & trick that will help you after reinstalling your O.S.: http://www.fixya.com/support/r4213055-quickly_reinstall_operating_system Cheers
May 19, 2010 | Sony VAIO VGN-FW390JAS PC Notebook
My laptop is slow and wont reboot
Put the Windows Op Sys CD in the drive and boot the system, Interrupt the boot process and go to the BIOS. Select the first boot up device to be the CD/DVD drive and then save the settings. Exit from BIOS and reboot the laptop. Windows should start from the CD. You will see an option to repair etc. Select the R Repair option and follow instructions. Once this has completed, and it may take some time depending on how full the HD is go to www.ashampoo.de and download the 30 day free trial application of Ashampoo and run this over your system to clean it up. Then run the defrag option in the MODULES tab - Optimise Performance Option- Defrag 3. Once completed your system will be cleaned and optimised. In order to make the performance even better - add additional RAM to the unit - you can never have too much and make sure that the HD has a minimum of 10% space remaining otherwise the laptop will slow down in operation.
Oct 13, 2009 | Computers & Internet
Acer aspire 5600awlmi going slow
Assuming stock LT go to start run and type msconfig and click ok. On the general tab select Diagnostic Startup and click ok, it will ask to reboot and seleck ok. After the reboot see if it is operating normally.
If it is working normally then some application is causing the problem. You can selectivly choose to launch one app at a time till you find the one causing the problem. Most likely is antivirus set too agressivley or spyware. Might consider a tool like spybot to clean the system.
Sep 21, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Slow starting Dell Inspiron 2650
The first thing I would look at is hard drive free space. Almost universally, critically slow systems have a hard drive with no free space. What most people don't seem to understand is that Windows requires a minimum of 10% of the hard drive to be free space to allow the operating system room for swap files and other temporary files needed to run the OS efficiently. This can be made worst by the fact that Windows only reports the size of a file on the hard drive, not the amount of space actually allotted to the file (This has to do with cluster size and the fact that only one file is written to any part of a cluster and in this case it is small files that waste a lot of space)
Things you can do.
1. Run disk cleanup, and get rid all temporary files.
2. If you use an email client like Outlook/Outlook express, delete unwanted emails, then empty the deleted items folder.
3. Open Internet Explorer, Tools, Internet Options, delete all cookies and temporaty internet files.
4. Go to add/remove programs in control panel, uninstall any programs or applications you do not use.
5. If you have a large amount of pictures or music files on the system, burn them to CDs or DVDs and free up that space.
6. Go to System Properties, Advanced Tab, performance section, settings button, select Adjust for Best Performance, Click Apply, Click Advanced TAB, Virtual Memory, Change Button, Select System Managed Size, Click Apply close then reboot.
7. Go to MY Computer, right click C:, Click Properties, Tools Tab, Defragment the Hard Drive
8. Adjust power management to Maximum perofrmance.
Nov 07, 2008 | Dell Inspiron 2650 Notebook
E-Machines M6811 Notebook Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
