Question about HP Officejet 5610 All-In-One InkJet Printer
Carriage jam (leftside)
Clicks several times and stops
  • 876541234567 Jan 29, 2009
    carriage(left side) jam clicks several times and stops
  • diane carter Jan 30, 2009
    the carrtridge slams a few times into the left side then finally moves over and starts to print, but in many cases it refuses to release the printed document (keep pulling it back toward printer) so I have to tug it free. Then I get the carraige jam message. What and where is the encoder strip that I'm supposed to check?
  • 31 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
317
Posted on Mar 18, 2009
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Hp officejet 4315 series carriage jam, makes a loud clicking noise then jams fases light. virginiarortega@yahoo.com
A lot of times this is caused by something that has fallen into the printer - I just pulled a necklace out of one - when the cartridges are not at the far left or right pull the plug on the printer and move the carriage until it stops and look for an obstruction there
Jan 15, 2015 | HP OfficeJet Office Equipment & Supplies
Dell 942 carrier jam loud banging
you going to have to replace the carriage ASSY. That sound means the carriage is offline and it needs repair or you got something blocking or jammed in the printer so good that its doing this.
Diag : bad carriage or severe carriage jam
prog: Repair/clear jame if any or new printer
Thanks please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
Carriage Jam on my HP Officejet 5610v All-in-One printer
If I move the carriages to the center of the bar they slide on (would be the center of the paper) and close everything it seems to re-load, I've had to do this several times over the last few years and so far it always works
Feb 09, 2010 | HP Officejet 5610 All-In-One InkJet...
Open door. clear carriage jam, and then press ok
Did you mess with the carriage because it will stop moving if you messed with it and that ain't very good...
Jan 16, 2010 | HP Officejet 5610 All-In-One InkJet...
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
HP Photosmaart C4200 All in one. I have a cartridge jam and don't know how to clear it.
When you open the carriage door, disconnect power, center carriage, close door and reconnect power...if there is astrip called encoder strip,its function is to tell the carriage location ,if its missing or unattached the carriage will hav all kind of problem in most hp printer like carriage jam.there may be obstruction to carriage movement there is ahook that sits on the leftside and a spring it sits on to give it some lleadway check it to see that it doesnt break, there is also a section of the carriage it slip thru also try to get it re attached or check for any obstruction as it slips thru.
Goodluck .
Oct 19, 2008 | HP Office Equipment & Supplies
Carrier jam, keeps poping up when switching on, wo'nt go away, printer is lexmark p6350
there is astrip called encoder strip,its function is to tell the carriage location ,if its missing or unattached the carriage will hav all kind of problem.
SOLUTION:there is ahook that sits on the leftside and a spring it sits on to give it some lleadway check to see that it doesnt break, there is also a section of the carriage it slip thru also try to get it re attached
Jun 01, 2008 | Lexmark Office Equipment & Supplies
Lexmark P6350, carrier jam
SOLUTION:there is ahook that sits on the leftside and a spring it sits on to give it some lleadway i checked to see that it doesnt break, there is also a section of the carriage it slip thru also try to get it re attached
Carriage jam
My wife had replaced bith ink cartridges and the carriage was also jammed! what she did was helped the cartridge carrier up some and it finally clicked in!!
Jan 23, 2008 | HP PSC 1610v All-in-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
