Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
At rinse cycle the washer whirls and hums like a air plane landin
The washer is about 5 years old. Once the washer is full it starts this whirling and clicking sound(like a solinod starting)and we turn it off. If you move the timer dial past the spin cycle it will drain and spin. I looked at the belt and clutch everything seems fine there.
  • birdcr Nov 29, 2008
    James about a month ago we had a blanket get stuck under the agitator inside the drum, I cut it loose as best I could. The agitator seems lopsided, how does one get it apart??
  • birdcr Nov 30, 2008
    Found an 1/8 inch drill bit that fell out of a pants pocket, the drill bit had jambed the agitator against the drum.
  • Frigidaire Master
  • 19,396 Answers
This sounds like a defective control assembly, or a defective solenoid.
It will be useful to understand exactly at what part of the cycle you get the problem.
Posted on Nov 29, 2008
  • Ginko
    Ginko Nov 29, 2008
    There is also an electronic module, called MCU that controls the motor, this looks like a sealed and waterproof protected box inside the appliance, near to the bottom. When this is faulty it can also make a clicking noise, and the motor wont start.
    You can find the replacement here.
    Sergeant:
  • 291 Answers
Check if some of the clothes got stuck up in the gasket and blocking the drum.if yes remove that clothes.
Maytag centennial washer why does it only run on the spin cycle?
Does your machine have a lock/start button?
It may very well be that the selector dial has some internal looseness or corrosion. Has the top control panel been wet?
May 26, 2014 | Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Not working-push button controls-do not work correctly-sometimes
You need to replace your user interface board. Always order with the correct model number on the unit. This will eliminate you issues
Jun 07, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
F1 code
well they refuse to adress your issue under a warr. beacause of age , but im certain that a whirlpool auth. servicer will glady adress your issue. As for the F1 generally relates to a faulety control board. but would want( a serveicer ) to check in more detail before jsut askin you to replace the board
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
