Question about GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher
My GE triton is not draining the water in the bottom - what to check before calling service
  • 1,543 Answers
You posted under a model GLD5860LSS, so it that is correct fine, if not, this may be slightly off.
First, and easiest, is to disconnect the drain hose at the very end where it connects to the drain or disposer and make sure there is not a blockage there. That is one of the more restricted areas (size wise) in the drain system, and a nut shell or seed or other item can lodge there and obstruct water flow out the drain hose. Second, would be to remove the plastic rectangular raised grate just behind and to the right of the lower wash arm. Look for obstructions there, like wire ties, candy wrappers, and other items. It may be easier to **** the water out with a turkey baster so when you stick your head in the dishwasher you'll be able to see back there.
Posted on Nov 27, 2008
GE Triton dishwasher occasionally won't drain all the water..still in bottom of dishwasher or leaks into floor. Not every time!
make sure that a portion of the drain hose was hung higher than the connection to the garbage disposal. hose should not have kinks or twists. if that doesn't work, clean (no clog) or replace drain hose.
Oct 07, 2015 | GE Dishwashers
How do I diagnose a GE dishwasher that doesn't drain at the end of the cycle?
The sensor responsible for telling the pump motor when to shut off is defective. Replace it.
Oct 14, 2014 | Dishwashers
GE Triton 24
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please post back for any further assistance.
Jul 23, 2010 | GE Dishwashers
My GE triton dishwasher has water standing in the
The GE GSD5500 has a check valve in the rear of the unit under the FILTER FRAME that screws in. GE part WD24X10018.
The white rubber stopper wears out and lets water return to the tub!
Remove filter frame (4 screws) and unscrew the check valve to replace. Try for part # AP2617344.
Nov 30, 2009 | GE Dishwashers
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton dishwasher will not drain and after cycle.
Look at the timer to see if the contacts have finally worn off. The circuit board may have failed too.
Nov 09, 2017 | GE 24 in. GSD4320Z Built-in Dishwasher
Ge Triton dishwasher will not drain and makes a funny noise.
Yes!! The crackling noise you hear is small pieces of food stuck spinning around the moter drain....All you have to do is find the drain hose (some are located under the sink of the kitchen) disconnect it from the draining source (not the back of the dishwasher) now run a long thin wire through the drain hose line poke around and pull in and out!! it may take a few tries but its better then a large Bill!! replace hose and hit drain button!!
Please rate response and help keep this site free!
Jan 06, 2009 | Samsung HL-S5087W DLP TV
GE TRITON LX Dishwasher
First check your Drain Cup filter it is just under the lower spray arm you may have something blocking the drain... if its clear check the drain pump... does it run a drain out? can you here it make noise? let me know if this helps ?
Aug 14, 2007 | GE ZBD5900D Dishwasher
GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Logo
157 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
