Question about Microwave Ovens
Sharp carousel microwave does not heat-up food.everthing else works, what can be the problem.
  • 3 more comments
  • mgftcampbell Mar 11, 2009
    Mine is a Sharp Carousel R-1514 1000 watts. The noise that the microwave makes is unusual. Its like a deeper pitch of the regular noise. The lights come on and the turntable turns and I can set reheat, defrost, or cook time. It just will run, but not heatup anything.
    Thanks
  • Anonymous Mar 22, 2009
    Sharp Carousel R-1501: Unusual loud noise; turntable & light work; doesn't heat. Magnetron?
  • Anonymous May 14, 2009
    I have a Sharp Carousel Model R395f(s), got it as a wedding present about 15months ago. Oven works perfectly except it doesn't heat anything. No weird noises, all buttons work, the interior light works while the oven is in operation and the turntable works.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises? Is it louder or quieter than usual?
    Do you have the model number?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • Ann Margaret Oct 03, 2012
    My Sharp Carousel does not work. All the buttons and light work, but the turntable does not work so the food does not cook.
MicrowaveSvc
  • 9086 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
  • 1214 Answers
SOURCE: Samsung microwave doesn't heat food.
Microwave ovens that do not heat, and failed as you have described, have 1 or more of the following failed components, in order of cost -
1) Fuse
2) Diode
3) Capacitor
4) Transformer
5) Magnetron
4 and 5 are interchangeable when it comes to cost.
Try replacing 1 and 2, then 3, then it's decision time of whether to buy parts or replace the microwave.
Posted on Dec 11, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
The service manual (available at our site) shows how and shows that the lamp is mounted in the air duct near the magnetron. See http://www.microwavedisplay.com/r510hk_hw_sm.pdf
Part # is RLMPTA086WRZZ and you should be able to get that generically locally but if not, you can get it form Tritronics at http://www.wehaveparts.com
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Nov 22, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave touch pad work light doesn't work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Dec 31, 2007
SOURCE: loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Posted on Sep 08, 2009
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
My sharp carousel II microwave no longer heats food. Do I need to buy a new one?
The problem maybe the magnetron, or the inverter board if 7 years old or less, and possibly the keypad control board, by the time you add parts and labour cheaper to replace the microwave oven in the long run.
May 07, 2012 | Sharp Carousel R530EST Microwave Oven
My micro wave stop heating food, every thing dislay work fine. when start it make loud sound. Sharp carousel II, model = R-3A54, Manufacture jan,1993
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 27, 2011 | Maytag MMC5000 Microwave Oven
I have a sharp carousel but the convection oven is not heating up. The microwave works.
heatman101 ,./';
May 24, 2011 | Sharp Carousel R530EST Microwave Oven
Sharp R-340H Microwave has power but does not heat food. Carousel working.
The magnetron is the likely problem, "heats food" the other two items to check is the high voltage capacitor and diode. It usually is cheaper to replace.
Apr 06, 2011 | Sharp Microwave Ovens
It's not getting heat and LCD looks like there's water inside.
On most Sharp Carousel Microwaves, the display stops working after time. As for the not getting any heat, the magnetron or the high voltage transformer may not be working.
Jul 04, 2009 | Sharp R-510HW Microwave Oven
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
Sharp Carousel Microwave Model R520-LK timer will run but carousel doesn't turn and food doesn't heat.
I also have the Sharp Carosoul oven, symptoms - fan runs, controls are fine but the turntable stopped turning and it did not heat. It was not the switches, fuse, but in fact a sagging door that misaligned with the door switches. The true cause was a warn top hinge. As a temporary fix, I adjusted the bottom hinge (3 screws underneath), straightened the door, and now it works again.
Dec 16, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
1,056 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
