Question about Estate TAWX700JQ Top Load Washer
Keeps filling up
Wont stop filling up when we start a new load every time also wont to know take unit aprt from back or remove top
  • 1,028 Answers
Ck drain hose be sure it is at least 36 ins from floor and fits loosely in standpipe if unit fills and over flows remove screws in console and lift up and back ck small hose to water level switch to be sure it is securely attached rmove cabinet remove brass colored clips under console unplug lid switch lean cabinet forward and slide off at bottom
Posted on Nov 27, 2008
Why dose water keeps filling wash when off oasis he 27082 top load
The timer turns the water on to fill, the pressure switch turns it off. If the water contacts are welded together (can happen over time) then the water solenoid will be on all the time. Easy way to check. Unplug the unit, then remove the electrical plug from the water valve (hot or cold depending which one is causing the issue) plug unit back in. If water stops filling the timer is bad. If the water does not fill then the timer is fine, but the water valve solenoid is bad.
Jul 29, 2014 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Wont stop filling with water
You need to replace the fill switch its not sensing or stopping the w ater. It is fairly simple. Remove the plastic molding on the ends. Remove two screws holding down the control panel. The fill switch is over to the left, and has a clear tube attached to it. Remove tube and wires, lift tab keeping it from turning, turn 45 degrees and remove switch. Replace and test in all positions. Good luck whirlpool is a good brand.
Jul 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Ge washer wont stop filling with water
The usual culprit for a washer that will not stop filling is the pressure switch. The switch is located inside the operator console behind the load size, or water level knob (this knob has different names based on the washer model). Before assuming the pressure is defective, however, inspect the pressure switch and ensure the small plastic air hose is still attached to it. It is common for this small air hose to come loose or develop small cracks or breaks. Without the hose installed, the switch cannot detect the appropriate pressure in the wash tub and will not shut off. The result: as washer that continually fills and will overflow. What appears to be a significant problem may only be a loose hose and few minutes of your time. Please inspect the switch, check the entire length of the hose for cracks and make sure the electrical connection(s) are intact and not corroded, then get back to me. I hope this helps you.
PS Make sure you UNPLUG the washer before servicing!
Dec 20, 2008 | GE WDSR2080D Top Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Wont wash
Remove lid then control panel. Unhook all terminals, remove control board, then second "box" which is further away towards back of machine. Sensor is 'back/right," under this second box. Unhook connectors & remove wee sensor carefully. On the side of the sensor is a tiny plastic button the size of a pen top. This should move in & out freely. It is spring loaded. If it sticks replace it. Good luck on your mission.
May 26, 2008 | Fisher and Paykel GWL11 Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
