Thread what is thread? why thread? what is need? what is use?
    Novelist:
  • 202 Answers
Just put the sentence in google and check u get lot of links
Posted on Nov 27, 2008
I need to know how to thread a brother lock 530 overlocker
How to thread brother lock 530 Brother Sewing Machines
Follow the instructions exactly. Each thread needs to threaded in the order stated in the manual. Threading out of order will guarantee failure. Also, whenever a thread breaks or comes unthreaded during use, it is very difficult to rethread that one thread and be successful. If it doesn't work the first time, just bite the bullet (save yourself some frustration) and rethread all the threads from the beginning.
NOTE: ALWAYS THREAD with the presser foot in the raised position! When threading through the tension disks, give each thread an extra little tug to make sure it is seated completely.
Jul 28, 2018 | Brother Sewing Machines
I am trying to thread and sew a 3 thread over lock stitch on a HL 1002. I think I have it threaded correctly but it will not sew at all. what settings do I need?
Try brand new needles.
Remove all the threads from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. BE SURE to thread each in the order specified in the manual. When pulling thread from the thread tree through the tension disk, give each thread an extra little tug to completely seat the thread in the tension disk.
If the threads are completely seated and threaded in the correct order, the machine should stitch. If not, then perhaps it needs service.
Jun 24, 2017 | Sewing Machines
I need a diagram of how to thread it or a problem solver the thread eeps breaking at the needle
Search the internet for:
Manufacturer + Model + the word "Manual"
or search YouTube videos for "sewing machine threading." You may not find your exact machine, but many machines have similar threading patterns. Be sure to raise the presser foot before threading the upper thread so it will seat properly in the tension disk.
If the thread is breaking at the needle, it could be several problems:
Threaded incorrectly--#1 cause
Upper tension too tight
Install a brand new needle compatible with the fabric & thread
Make sure the thread is not too large for the needle eye
Avoid old, fuzzy, bargain bin thread
All About Needles
Dec 24, 2015 | Necchi Sewing Machines
Will not accept heavy duty thread. sews with bunch-up on bottom of material
the top thread tension is too loose
tighten it up a lot
Dec 12, 2015 | Sewing Machines
Need to chase thread on o2 size?
use a thread gauge to get the pitch of the thread ( threads per inch) measure the diameter of the o2 sensor and get a thread tap from a ool shop to match
some are BSP thread which is a taper so be careful that you do not remove any more metal than is necessary from the thread
May 19, 2015 | 2005 GMC Envoy
The top thread does not pull up the bobbin thread
Is the bobbin thread through the needle eye? If not then it needs to be there. The top thread doesn't pull it.
May 07, 2015 | Bernina Activa 130
Constantly breaks threads
The thread sensors may need replacing, but meantime make sure that your machine is threaded correctly with the upper thread going into the tension disks. The presser foot HAS to be up when you are threading so that the disks are open and ready to receive the thread. I pull off about 15 inches (40cm) of thread then hold the thread where it comes off the thread spool. Use the thread you pulled off to go through the thread guides and tension disks down to the needle. Tug the thread (you are still holding the thread at the top near the spool) before threading the needle to be sure it is seated in the tension disks. Also make sure that once you have threaded the needle, there is a decent sized thread tail so that when the machine starts, the thread is not going to pop out of the needle's eye. Hold onto the thread tail (I lay it on the machine bed and just put my finger on it) for the first few stitches. Having this little bit of tension on it helps to make sure the bobbin thread comes up and makes the first stitches. Sometimes if this does not happen, the top thread is pulled underneath and the "Thread Broken" pop-up appears. If checking that the machine is threaded correctly top and bobbin does not solve the problem, you need the sensors checked by a machine technician.
Dec 05, 2010 | Husqvarna Designer I
Can't get the needle thread to loop over the bobbin thread. The bobbin thread is already thru the hole.
You only need the thread to loop over the bobbin thread to bring up the thread when you are threading the machine. If, you mean it is not sewing after threading then I need more information.
Nov 17, 2010 | Singer Pixie Plus Sewing Machine
Need threading instruction for white sew ez plus childrens machine
Raise thread spindle by graspi G the expose s too and pulling up wears until thread spinale is fully extended, Place thread spopola on the three ad spindle. Pull thread from the thread on the thread spopola on the thread spinale and put it through the thread holder in the direction toward front of macchine. Bring thread a cross to the thread tension screw. Thread goes over the tension adjusting screw and must be position ed between the two washers beh ind. The tension adusting screw. This is what provides the lockstitch tension to the thread. Pull thread from tension adusti G screw guide through thread take up lever in the directions tovwarped front of machine. Pull thread through thread guide inserting in the direction tosare the front of the machine. pull thread down to thread guide and insert thread from the top downward. If necessary, loser the neede to reach this guide by turning the handwheelslightly counterclockwise (in the directions foward you) to loser the needle. Raise the need le to reach the eye by turning the handwheel slightly counterclockwise (toward you) insert thread through eye of the needle from the front toward the back of the machine ( use threader accessory if necessary) raise the presser foto by lifting up on the lever st the rear of machine. Pull about 10 inches of thread through the needle and lay it on the deck under the presser foot running in the directions away from you.
Feb 14, 2010 | Sewing Machines
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
