Question about Dell Latitude C610 Notebook
Dell C610 laptop
I have the problem where I am looking for the instructions on how to remove and replace with a new keyboard on a Dell C610 any one have any ideas please?
  • andyeparry Nov 27, 2008
    • Thank you Pankaj_dic your comments are correct of course however unbeknown to your self I am an electronics engineer and have been for the past 30 years however I am not prepared to start this job with out the relevant information for the very reason you eluded to in your response.
    This still leaves me looking for the infromation on how to remove and replace with a new keyboard on a Dell C610.
    Genius:
  • Dell Master
  • 1,250 Answers
If you are not sound on technical ground its better consult the technician, becaulse there are small cables and screws attached, a minute displacement may cause problem
Posted on Nov 27, 2008
The delete key is no longer working on my laptop. Any advice? Nothing changed in status that I can remember to cause it.
How old is your laptop; I had similar problems with my Dell Studio a few months before and I found out that the rubber 'things' under the keys are damaged and no more functioning because of the extensive usage.In this case you need to replace your keyboard (If you are under warranty then you can get a replacement). If your warranty is expired buy a keyboard and fix it yourself it is not that hard to do follow the instructions here to do it yourself : http://dell.to/ax0ph5
Also check if there is something stuck underneath the key, if something is there use a small safety pin sized thin and flexible rode to remove it (some times this will solve your problem).
Jul 27, 2010 | Dell Latitude C610 Notebook
I have a stuck key on my lab top computer but i do not know witch one is stuck how do i determine witch key is stuck. this is on my dell latitude c610 labtop
Hi:
There is not an easy way to see which key is sticking on your laptop. The good news is that a replacement keyboard will fix the problem, and it is easy to swap out, and not too expensive. They are usually only about $20 on ebay, and instructions are available too. If you buy a keyboard, and don't feel up to changing it, most computer shops will help you swap it out for not too much cash...
Hope you fix it!
May 03, 2010 | Dell Latitude C610 Notebook
Dell Latitude keyboard issue
It is the direct access button, it (originally) is to run Dell utilities installed on the system. Generally it is ignored by most users. In theory it can be reprogrammed in Control Panel, Keyboard Properties, Direct Access Tab
Jul 01, 2009 | Dell Latitude C610 Notebook
Dell C610 battery cmos/bios
The removal and replacement instructions can be found in the dell service documents available at support.dell.com. You can look it up by service tag or model number. But in short, the procedures are. 1. Remove the hard drive, then remove the keyboard. The keyboard is removed by removing the 5 screws on the bottom of the laptop marked with a "K" beside them. Then the keyboard can be removed. be careful not to tear the ribbon cable, and you do not have to remove the ribbon cable. The battery will be in the center of the opening, it will have a white plug that plugs into the keyboard. Contrary to Ayyasam's recomendations above, it is not necessary to remove "all" the screws on the bottom, nor is it necessary to remove the bottom of the laptop. It should be a 5 minute project. Again for any Dell item, the factory repair manuals are available online, and have exact instructions including pictures and diagrams.
Happy Computing
Daver56
Jun 04, 2009 | Dell Latitude C610 Notebook
Keyboard problem
You just need a new keyboard - those are easy to come by check ebay.com and search for C640 keyboard. New ones should only be about $30-$40.
To remove the keyboard you just remove all the screws on the bottom of the laptop that are marked with the letter "K" then carefully pop the keyboard up.
Let us know if you need further help!
Jan 12, 2008 | Dell Latitude C640 P4 Mobile Notebook
Keyboard
This is a rather old question, but the solution might still be helpful to other readers.
I suggest you call Tech Support at Dell...
Several years ago, I worked on many Dell CPx 500 models in my work place. There was an issue that always involved a series of 4 or 5 keys (they were always the same keys) that would quit working and we had attempted to purchase new keyboards to fix the issue. It turned out, the real solution was to replace the 'motherboard' of the Latitude notebook!
Dell had knowledge about the keyboard/motherboard issue that we didn't know.
Jan 11, 2008 | Dell Latitude C640 Notebook
Cover stripe damaged
sure they are the same on the c510 and c610 laptops.
i see them on ebay all the time for $5-$10.
look for c610 power button on ebay.
Dec 16, 2007 | Dell Latitude D600 Notebook
Dell latitude c610 keyboard prblem
hi what you can try is
going into device mannager and removing the keyboard (un install)
then re install
but if you think there is a bad earth between the back of the k/board and the inner tin then place a sheet of paper between them and see how that goes
hope this helps
Nov 10, 2007 | Dell Latitude C610 Notebook
Dell Latitude C610 Notebook Logo
69 people viewed this question
Alun Cox
