Question about Ovens
F2E1, F3E0 Error Codes
I was getting a F2E1 error on the display panel of my oven, which indicated a UL A/D error. When the control and circuit board were replaced, the new panel then displayed the F3E0 error which means 'Oven sensor opened' according to the Tech Sheet. What would be the fix from there? I have a KitchenAid Superba convection oven. After putting the turkey in this morning I obtained an F2E1 error code after about 1.5hrs of cooking. I let the oven sit or awhile then noticed if I hit "Bake" instead of convection the oven would come back on. What do I need to do? I use convection all the time....Jack
  • johnacurci Nov 27, 2008
    We have a slide in electric oven, we have had the same problem twice before. The repair man puts a code in to fix it , but he won't tell us what that code is. This morning it happened again! about 2hrs into cooking the turkey, we are extremely frustrated with this oven, any help would be greatly appreciated.
  • radernb Jan 03, 2009
    Brand new oven, used once. When I tried to turn it off, I got error code F2E1. Of course it happens on a Friday night.
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Posted on Mar 30, 2008
SOURCE: kenmore oven touch panel error codes f1 f3 f5 f7, oven failure
I had the same problem. It occurred when it was in a cleaning cycling. I fot the F3 Fasult and also the door remained locked. I let it cool down overnight and killed the power at the circuit breaker. I turned the power on and got a F3 alarm and the door remained locked. I took our the screws holding the control panel and pull it out far enough to give me access to the locking mechanisim. I took out the screw holding the locking latch to the motor. With the latch loose, iwas able to get move it out of the door lock. With the door now open I was able to get to the temperature sensor with was held with two sheet mmetal screws. The screw were impossible to get out, so I ground off the heads with a Dremel tool. I couldn't get the sensor wires out. So I pulled the unit out to get at the back sde. I cut the old sensor wires and was able to get in the hole to remove the screws with a pair of needle nose pliers. I installed a new sensor and with wire nuts attached the sensor wires to the computer wires. Make sure that you work the insulation in the hole to plug it back up. Put the oven back in and installed the sensor in the oven with two small sheet metal screws. . refasten the locking latch to the locking latch motor. turn on the power and everything was fine. I ohmmed out the old sensor and it was 180 ohms at room temperature. The replacement checked out at a 1000 ohms in accordance with the schematic for the control. By the way, the schematic was neatly folded on the control panel when I removed it I used a Whirlpool sensor Part No. 12001656 which was half the price of a Kenmore sensor. +
Posted on Oct 24, 2008
  • 338 Answers
SOURCE: Set probe temperature
If i remember correctly i believe this is actually a wiring issue. you would need to turn the power off open the control panel. and look for a control board with the probe connection on it. there should be a tech sheet in the compartment to help you identify it however if it is the problem they would be purple wires on the connector that need to be reversed.
Posted on Nov 28, 2008
barkencoa
  • 3463 Answers
SOURCE: oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Posted on Dec 14, 2008
Error F3E0
next time you see the error codes, write them down. F3E0 is open sensor error . I don't think you have an oven sensor error or a problem with the sensor. When the oven works the temperatures are good so the sensor won't be open. F0E0 is "No Error" and "No Action Required". It sounds like a loose or a bad connection in the control section. There is no connection between the oven door and the control panel. Opening and closing the door to clear error codes or to get the oven to work is jarring the control and the loose or bad connection to the point it makes contact and works. Start with the ribbon connector and remove and reinsert it. You can also use a pencil eraser to gently clean the end of the ribbon connector. Remove and reinstall the wire harness connectors on the boards. Make sure all the pins in the connector are in place and not starting to come out the back of the connector.
Sep 30, 2016 | Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
Wall oven stopped working
Good Morning Peggy, thank you for allowing me to assist you!
Typically error code F1 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Dec 29, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
F4 code is displayed and oven beeps continuously
Hello Duane, I am happy to assist you. Typically, error code F4 indicates a lockout error. Try resetting the unit by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) or the Lockout Control Board on the appliance will need replacing.
Aug 16, 2013 | Frigidaire 27 in. Electric Double...
KEMS308SSS KitchenAid Wall oven - Error F3E0 - Sensor seems OK
The RTD could be in spec at room temperature but failing under load
May 21, 2013 | KitchenAid Architect® KEMS308SSS Stainless...
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
My oven gives error code f2e1, how do i solve it
F2 E1 means that the keypad cable is unplugged.
Gain access to the control panel and keypad. Check keypad connector for firm connections. Keypad connects to the control board. Press CANCEL. If error code returns after 60 seconds, the keypad needs to be replaced. If your control board and keypad are incorporated as one unit, then the control board needs to be replaced.
Feb 14, 2011 | KitchenAid Ovens
Err F2E1 stuck/shorted key
The control panel is either faulty and needs to be replaced. One can be purchased at repairclinic website or partselect.
Or you can dismantle it, and clean everything with rubbing alcohol and a cotton swab
Apr 27, 2010 | Ovens
F2e1 error message
It is the only ribon cable coming off of the control panel to the control board. This error could also indicate that the control panel is bad.
Apr 12, 2009 | KitchenAid KEBC107 Electric Single Oven
Ovens Logo
225 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
