The laptop switches on but the display isnt working
    Genius:
  • 1,250 Answers
Check the display on external monitor by connecting it through the VGA port of the laptop, if the display is there then its the problem of display panel, its better take it to the techncian near you
Posted on Nov 27, 2008
What is the correct code to press on my hp htsnn-105c to display on external monitor?
If it was the inverter, there would be a black screen. Do you get startup display? If you do it is definately not the inverter.
Aug 15, 2014 | HP Computers & Internet
Hp g60-214em screen wont come on hdmi still works when windows running but screen isnt
Try toggling the screen. Normally when you toggle the screen it has 3 stages for the display. 1. Laptop only 2. TV only 3. Both Laptop and TV
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 16, 2012 | Computers & Internet
I have been using my Iogear kvm switch for almost 2 years now to switch between a desktop and a laptop, both Windows XP. I unplugged the laptop in a hurry to go do a presentation, and plugged everything...
This almost sounds like the display setting on your laptop was changed to an external device. Most laptops are designed to be hooked up to an external display, such as a monitor or projector, specifically for presentations. You can alternate the display options in the following ways:
  1. Laptop display only
  2. External display only
  3. Laptop+External clone
  4. Laptop display + extended desktop on external display (dual monitor setup)
Check your laptop display settings and make sure that it's not in presentation mode (options 2-4) before connecting the KVM switch to it. It may be recognizing the KVM switch as an external display in option 4 mode.
Mar 25, 2011 | IOGear GCS634U KVM Switch
My dell isnt showing the display on the screen , but dose when connected to a projector ??
The LCD display of your laptop is damaged.
The only way to fix this, is to give it to an expert and ask him to change the LCD display.
Jan 21, 2011 | Dell Latitude D800 Notebook
My freezer isnt working
this may sound stupid but is the ice maker turned on? Does it say "ice" in the display? If it does, check to see if the ice level arm is jammed into the upper position also make sure that the ice bin is in place (it actuates the ice maker switch) make sure there is no ice stuck to the top of the ice maker
Jun 16, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Fixed wireless internet, now browser says cannot display webpage
Try updating the driver for your wireless card first. If that doesn't work check with the router company to make sure your card is compatible with their router. When I buily my new computer my ethernet card needed swapped as the onboard driver was not compatible with my router.
Dec 21, 2008 | IBM ThinkPad R50e Notebook
Sony vaio VGN FS 570 no display
Try having your battery tested. There may be not enough power to run everything on your comp.
Anotherthing to consider, if your CPU fan isnt working the bios wont start the O.S. as the CPU will overheat and shut down automatically. Good Luck
Oct 14, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
