Question about Belkin (F5D5231-4) Router
Connection keeps cutting out
My connection cuts out between 10 and 20 times a day. I have to keep switching it on and off to get it working again. It even cuts out when a door is slammed or the dog barks!! BT assure me I have a stable line, I can only assume its the router? Any Suggestions?
  • atengineerin Dec 01, 2008
    I have checked the cables, they seem to be ok. I will try the set up Wizard when next at home. Many Thanks.
  • 128 Answers
Have you checked your cable / DSL modem? It could be a loose or faulty CAT5 cable - or inproper software settings in the router. Type 192.168.0.1 or 192.168.1.1 in your browser address line - and look for the set up wizard - follow the bouncing ball.
Posted on Nov 27, 2008
ECI Fuse keeps blowing
What ever was blowing the fuse intermittently now has a full blow dead short. Trace it through to the unit and check for connections shorting out or the unit itself shorting out.
Jan 10, 2014 | Cars & Trucks
Pride elite traveler keeps cutting out 9 beeps
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Dec 13, 2013 | Pride Mobility Products GoGo Elite...
Encore Premier 36 walk behind- safety switch connection problem
you can adjust the handle not the switch try and swapping the switch with the other side and see if the problem follows the switch
May 12, 2012 | Garden
My sub keeps cutting in and out, it sometimes works than cuts out or I will start the car and it works and when I turn it back on again doesn't.
Your amp may be going into protection or you might have a loose connection. Start with your ground wire to make sure it's a good ground. The check all the other wiring. Hope this helps.
Aug 26, 2011 | Car Audio & Video
I keep on getting cut off the internet. i get back on then i get cut off again. i have new filters where the phones are. The 2nd from the bottom light turns red. and i am hard wired to the 2wire059. how...
hi good day,
i do believe that you got that router from your internet provider?
what i can suggest is have them replace the modem because it's not normal for that modem to cut your connection more often. call your isp now.
May 11, 2011 | 2wire (2701HG-B) Wireless Router
The Alarm keeps going off , previous owner cut the horn wires so that part doesnt work but the lights just randomly start blinking and going on and off and cant cut it off. remote key chain is no longer...
The day time running light module on the back side of the front drivers fender likely needs to be replaced to fix your problem.Unplug it and the lights will work normally from the headlight switch but the day time running lights won,t work and also the high beam indicator light in the dash won,t come on when you switch to high beam but all the lights will work properly.You should replace the drl module as soon as you can but unplugging it will at least keep you from having to remove a battery cable.
Sep 17, 2010 | 1993 Dodge Dynasty
The headlights keep cutting off when driving at night. Only temporarily and then go back on again.
Must Be Lose Connection In Main Connector Of Combination Switch. Thanks.
Jan 15, 2010 | 2001 Hyundai Accent
The air con on my 2000 N16 pulsar keeps cutting out...sometimes it works fine but other times the light wont come on on the button and the air doesnt cool when this happens.is it a loose connection?
It could be a loose connection or bad section of the HVAC module, yes. If it checks out I would check the pressure in the high/low side which could be tripping the switches to cut a/c operation.
Aug 29, 2009 | Nissan Pulsar Cars & Trucks
WIreless router - internet connection cuts out
there might be a signal problem repair the connection to change its ip address by right clicking on the connection icon which is found at the bottom left beside the clock if the problem still persists, check the cables of the router
Feb 10, 2009 | Acer Aspire 5100 Notebook
Belkin (F5D5231-4) Router Logo
140 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
