Question about Masterbuilt 20010306 Deep Fryer
Unit will not start no light no nothing
Unit does not work
Comes on at 200 degrees. States err. beeps continualy. will not start.
Posted on Dec 05, 2008
AlvinInside unit fan works; outside unit does not come on. Inside unit showed H5 code once. How do I proceed?
H is most likely for heat pump, meaning error 5 on outdoor unit. My guess would be low pressure since your power to the indoor unit most likely comes from the outdoor unit. Check manual for codes or research model number error codes.
Jun 03, 2016 | Fedders Heating & Cooling
Outside unit is not working
Aside from checking the circuit breaker for the unit, the unit should be looked at by a qualified service technician. You would need certain test instruments and a working knowledge of the unit's operation system to find the problem.
May 26, 2014 | LG LSU307HV 30,000 BTU Ductless SingZone...
I have a Didtal Decorating Instant Light Show WL-D and I can't get it to work!
OL means "OverLoad". the light you are using is drawing too much current. use a night light (7watts) or a 25w bulb in a lamp. I haven't been able to find the max wattage the unit can handle. I am running 3 25w bulbs in a traffic light and it seems ok. when you start the program there is a long pause before it starts. seems like it isn't going to run but after a few minutes it starts. if the OL comes up with nothing plugged in then the unit is bad.
Jan 08, 2014 | Hardware & Accessories
My BTM 630 starts a very anoying noice after I raise the volume up from 13. I believe it has to do with the ventilation. Do you have any idea?
I found this user review that may coincide with your experience...
"When receiving the unit the fan was very loud and the cd player did not work. However, after calling phillips that same day they mailed a new "referbished" unit out with prepaid postage and pickup service for the old unit. The new one works great and sounds great in a smaller room. Sound is very crisp and clear."
Negative Opinion after several replacements:
"worst product ever by adiklaus - November 14, 2009
Pros: The third replacement unit is still not working, Philips send two faulty replacement units. All displayed signs of previous use and did not work. CD player was not working, the same in second unit, the third unit had no working display .
Cons: For the short time it worked the unit was adequate in sound quality but unfortunately this was short lived.
Review: I certainly dislike a product that does not work and is backed up by second hand unit which also do not work. Beware of this Unit"
Mar 01, 2011 | Philips BTM630 Shelf System
My blinkers dont work. fuse is good. hazards work. what might the problem be
locate the hazard flasher unit under the dash by turning on flasher and feel flasher unit clicking. the turn flasher unit looks ths same and is close to the signal flash unit and may be interchangable. switch the 2 units and see if the turn flashers work now and replace faulty flash unit
Feb 12, 2011 | 1999 GMC Suburban
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Unit assembled, lights are on (pulse, on) nothing happens
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Jul 19, 2009 | KitchenAid KFP740 Food Processor
Masterbuilt 20010306 Deep Fryer Logo
205 people viewed this question
Top Masterbuilt Kitchen Appliances - Others Experts
Richard Lilja
Richard Lilja
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Masterbuilt Kitchen Appliances - Other Expert? Answer questions, earn points and help others
