Question about Digital Audio (DADVDP) DVD Player with AM/ FM/ RDS/ 5.1Ch/ 4 x 40 Amp Car Video Player
SD card slot damaged by spouse, she remove sd card to re-insert her video sd card and did not know that card had to be inserted right side- down. After forcing the card, she said she felt like something gave, but nothing came on the screen. When she got back, I removed the SD card and realized what had happened. Can the SD carriage be repaired and where does it need to go I used the GPS quiet often.That feature is only enable via the SD card.Model is T265 7" two Din dvd w/ gps touch screen.
Sim card for Samsung Galaxy tablet 4?
A SIM card is for 4G LTE internet service, so if you have a Samsung Tab 4 ensure it is 4G capable before trying to insert a SIM card. If you try to insert a SIM card into a SD Card slot you may damage the card reader.
That being said, I believe it is located on the right side of the tablet. Sometimes the SD Card slot and the Sim card slot are right next to each other. Once you open the cover that reveals the slots there should be small icons for the SD Card and the Sim card. Normally, the SIM card slot will have a little notch on the icon. Attached are guides with pictures.
http://www.samsung.com/us/support/answer/ANS00030415
SIM card Samsung Galaxy Tab 4
Oct 22, 2016 | Samsung Tablets & eReaders
Where do i stick my sd with adapter on my dell inspiron 1545
Most portable SD stick readers come with a USB connection so you just stick it into any spare USB port (see USB adaptor pic).
If you have an SD to SD adaptor that fits a small SD card into a larger SD card holder (see SD adaptor pic) then you also need one of the SD stick readers (above)
Sep 23, 2014 | Dell Inspiron 1545 Laptop
Sony xperia miro manual
Here's a link to the official user manual for Xperia Miro (http://blog.clove.co.uk/wp-content/uploads/2012/09/Sony_Xperia_Miro_Userguide_EN_ST23.pdf). On page 8 they described how to insert a microSD card into Xperia Miro.
Aug 21, 2014 | Sony Xperia miro ST23i Smartphone -...
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
HOW DO I CHANGE THE SD CARD ??
These are the physical specs of Kodak Easyshare V530
The bottom and the top of Kodak V530
The left side and the and the front of Kodak V530
The back -lcd display and the right side of Kodak V530
On the right side of the Kodak v530, just look at the above image, you will see a slot in the center of the silver band covered with white felt curtain that protects it from dust. On this slot is where the SD card is inserted. Just insert the card carefully, and feel the click when SD card is placed properly, and push the card carefully until it bounced back and release from the slot when removing the SD card.
Jul 18, 2010 | Kodak EasyShare V530 Digital Camera
Where do i insert the sd card in the G1 phone?
slide up the keyboard, on the bottom right side you will see a small covered slot, remove cover and insert sd card.
Nov 05, 2009 | HTC G1
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
I dont know where to put this
Hi, First insert the micro SD into its adapter which resembles a SD card itself but has a small opening at the bottom to insert the micro SD. The adapter should not b locked while inserting or removin the micro SD. Now insert the adapter in the card readers slot which should be connected to a PC via a USB. If its a card reader then insert the adapter with microSD in the right side top corner of the card reader with the adapters copper pins facing down. OR if u already have slots in ur CPU to insert the SD card install it there, Now transfer files to ur card happily. NOTE: Rename ur device so that next time when u plug it in the adpter n connect it to PC, u wont get confused. Just right Click on the drive icon in ur PC n select rename n just giv any name as u lik. Rate he soln dude Bye..........!
Jan 25, 2009 | PNY 2GB microSD Memory Card
SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
Sep 29, 2008 | HP Photosmart M525 Digital Camera
Car Audio & Video Logo
24 people viewed this question
Top Digital Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
