Question about Kenmore 24 in. 17032 Built-in Dishwasher
Upper Spinner Falls off
The "Spinner, 3rd level wash" keeps falling down into the washer. When I replace it it snaps in but apparently not firmly enough. Suggetions?
    President:
  • 878 Answers
Rachir...I believe the manufacturer redesigned this spinner. You can find the part at this link http://www.repairclinic.com/0080.asp Catriver...post back.
Posted on Jan 13, 2007
Then chain keeps falling apart
I imagine you have probably figured this out by now, but I'm going to go ahead and answer it anyway because when I searched for an answer to this question ealier today, I couldn't find one anywhere.
It is not initially apparent, but the chain pieces snap together. When you try to put them together, they seem to just loosely fit in place, but if you PUSH them together, they will snap together very easily and hold together without any problems.
Jul 03, 2012 | Viper K'nex Corkscrew Coaster, Vertical...
Water from the sink fills up the dish washer
I had a similar problem with a washing machine, until I replumbed my waste pipes. My Washing Machine waste pipe was attached to the down pipe just under the sink bowl. I found that the U bend trap was too high and the water level in the U-bend was at the same level as the Washing machine waste pipe was attached. So we has syphoning back into the washing machine. I moved the U bend trap down by 3 inches 7 cm, so now the water leaves the washing machine falls the 3 inches to the water level of the U bend. We now have no more syphoning back into the washing machine.
Jul 05, 2011 | Tricity Bendix 18 in. DH090 Free-standing...
Upper spray arm falls off during operation, even after snapping
the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
Feb 04, 2010 | Frigidaire Professional Series 24 in....
The upper sprayer arm fell off on my Frigidaire FDBB4365FC0.
I just had the same thing happen and fixed it! You might need to remove the upper rack first. In the "Roof" of the dishwasher, you should see what looks like a plastic gear wheel. It will screw off, but you will need to put a little force to get it started. Inside of the gear is a free floating plastic ring with 2 small teeth on one side. Make sure the teeth are facing down through the center hole of the wheel. Hold the ring with one finger, and snap the spray arm back in place. Just screw the assembly back into the washer and all is good... Until it falls out again...
Mar 21, 2009 | Frigidaire PLD4375RFC Dishwasher
I have a Kenmore Ultra Wash Dishwasher and the 3rd level spinner broke off. I have a new one and now need to know how to replace it.
the manifold in the back of the dishwasher needs to come out. you can either pop it all the way out it only undo it halfway if your arm is small enough.. there are either 2 tension clips or 2 screws holding it to the top and back. if you undo the top of the manifold and pull it down you should be able to slide the new part in place. the plastic push pin goes on top of the manifold and the spinner goes on the other side. it may be a little difficlt to push the 2 together..
Mar 06, 2009 | Dishwashers
The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
I had the same problem, the 3rd level spinner falling off. Without getting into my saga story, save yourself some $$$.
-You will need a screw & washer to replace the plastic thumbtack. The screw will have to be able to screw into the female part of the spinner; the washer will keep the screw from falling out of the hole in the flat hose on the ceiling of the dishwasher.
-If you look closely at the spinner(the part that keeps falling off), you will notice it comes apart. With a flat head screwdriver, separate the 2 parts. (there are 3 parts all together; Keep the round center piece sticking out of the top peice)
--Remove the top drawer of the dishwasher to give you some room to work
-Remove the screw on the "ceiling" of the dishwasher(it is located further back from where the spinner goes) to allow the flat pastic tube to come down low enough for you to get in behind it.(set that screw aside in a safe place; you will put it back later)
-Remove the pastic thumbtack from the hole in the flat plastic tube if it is there & replace with a washer and screw.
-Take the top 2 peices of the spinner, together as assembled & screw the screw into the female portion of the spinner.
-snap on the 3rd piece of the spinner
-replace the screw you took out earlier, securing the flat plastic tube.
-place top drawer
Voila, you are done!! You just saved yourself $20+
May 12, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Whirlpool ghw9100l belt will not stay on drum drive pully
I already fixed this problem with the same washer. You need to replace the metal yoke that spins. Its loose. Remove and replace the nut also that hold the yolk.
Nov 07, 2006 | Whirlpool GHW9100L Front Load Washer
Kenmore 24 in. 17032 Built-in Dishwasher Logo
224 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
