Question about Canon FAX-L380 Plain Paper Laser
Error code 00
I can not sand fax
  • 1,219 Answers
Replace fixing assy.
Posted on Jun 14, 2010
Waeco cf50: error code is 3 flashes
This company website is: www.waecousa.com
SPECIFIC product information
including "for service" suggestions, is here:
http://www.dometic.com/enus/Americas/USA/RV-Products/Portable-Refrigerators/products/?productdataid=81811
You can download the product manual
at the (elsewhere) link below - however it does not include the error codes:
Download Manual - DreamMaker Hot Dog Carts:
www.dreammakerhotdogcarts.com/manuals/cf-series.pdf
Lastly, while not what you specifically asked for, here is their (lengthy!) 'Plan B' contact information. Hope this helps!
For RV products:
Customer Support Center
2320 Industrial Parkway
Elkhart, IN 46516
Phone: 1-800-544-4881
CustomerSupportCenter@DometicUSA.com
Sales and Marketing
Elkhart, IN 46516
Phone: 574-294-2511
Fax: 574-293-9686
Recall Department
Dometic Corporation
Recall Phone Numbers:
Servicers: 888-803-0013, press 3 and enter your account number Consumers: 888-446-5157
Recall Fax Number: 574-389-3955
For Marine products
SeaLand and VacuFlush toilet systems and products
Dometic Corporation
Sanitation Division
P.O. Box 38
Big Prairie, OH 44611
Sales and Customer Service
13128 State Rt 226
Phone: 1-800-321-9886
Phone: 330-439-5550
Fax: 330-496-3097
sealand@dometic.com
For Dometic's air conditioning systems
including Cruisair and Marine Air Systems,
and other Adler/Barbour, Grunert, Eskimo Ice
and Sentry products -
Dometic Marine Division
2000 N. Andrews Ave.
Pompano Beach, FL 33069
Phone: 954-973-2477
Fax: 954-979-4414
Tech Support 8:00 AM to 5:00 PM ET: 800-542-2477
Tech Support After Hours & Weekends: 888-440-4494
MarineSales@dometicusa.com
Marketing Division
Phone: 954-973-2477
Fax: 954-970-8703
For Truck products
Dometic Corporation, Environmental Division
P.O. Box 15299
Richmond, VA 23227
Phone: 804-746-1313
Fax: 804-746-7248
sales@dometictruck.com
For Hotel products
Toll Free: 800-301-8118
lodging@dometicusa.com
Dometic USA
PO Box 490
Elkhart, IN 46515
Phone: 574-294-8665
Fax: 574-294-3369
Nov 09, 2014 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
The printer wont printer and displays "Unable to Print. See Troubleshooting and Routine Maintenance Chapter in Users Manual"
Unplug the printer for about 15seconds and then plug back in and power up.......this should reset the error code! Test print and you should be good to go!
Oct 05, 2014 | Brother Mfc9420cn Mfc-9420cn Fax Modem...
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors
www.equipmybiz.com EquipMyBiz
Aug 04, 2014 | Sharp MX-4101N Multifunction Printer Color...
Error code m420u
Error codes on the copier are of the format X0-00 ; this sounds like it may be a fax reporting error
Nov 20, 2013 | Sharp AR-507 Copier
We receive a partial or a blank page for incoming faxes followed by an error report pade with a 00-23 Quick Service Code. Can you help?
too many errors during reception
check the line 1st
too much noise on line
if its all the time from different ppl my guess is its ur end
connect a phone dial 1 and listen to the line if u hear any noise then its u
Nov 10, 2010 | Ricoh 3320L Laser Fax
Error 00-00-00 30-00-28
The error code will be due to bad batteries. Insert new batteries fully charged the camera will instantly try to zoom in or zoom out to adjust focus. If this does not happen then there is a problem with the Lens Assembly.
Lens has been forced due to an accident or too much sand or dirt is clogging it up.
You need to re-calibrate the focus.
Hope this helps.
Jan 26, 2010 | Ricoh Caplio G4 Digital Camera
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
Error H3 00 appears not found in guide book
H3-00 Heat roller high temperature detection
The fusing temperature exceeds 240C°.
Thermistor abnormality.
The easiest and cheapest solution is to replace the fuser.
This is very typical of a laser machine as some point the fuser will go out.
These little machines have a disposal fuser unit. It is possible to replace the parts. After the time and parts, in the long run it is cheaper to replace the whole unit.
Jan 28, 2009 | Sharp FO-DC550 Laser Fax
NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
Jan 09, 2009 | Sharp UX-B750 Inkjet Fax
Canon FAX-L380 Plain Paper Laser Logo
62 people viewed this question
old marine
old marine
