Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Pilot light keep going out will sometime stay on 3 hours then go
I have a continuous problem with my Coleman Evcon 7900 series.
The pilot light will light fine and the unit will work for a while then the
light goes out. A professional technician have replaced parts and cleaned out the pilot light debris. It worked fine for 8 hours and the pilot light went out again. The technician return and the same problem still
exist. What can be causing my pilot light to go out?
Email me at violalynndavis@yahoo.com
  • 2 more comments
  • violalynndav Nov 30, 2008
    To: Accurate Joe
    The thermocoupler and flame sensor was replaced. Also, the pilot and oriface
    was cleaned. The heater pilot light stills goes out. I attempted to light the pilot and
    the flame went back out. I waited 5 minutes to relight the pilot and soon I entered
    pilot door with the match the flame busted out the door. I was very fortunate I was
    burnt on just my hand. I will call another technician in the morning.
    Accurate Joe what appear to be the problem with this pilot light.
  • Anonymous Feb 18, 2009
    Pilot light only stayed for 3 hours after it was lighted. New sensor has been installed, but it didn't fix the problem.
  • Joseph Lillie
    Joseph Lillie May 11, 2010
    A couple of things. Does this unit have thermocouple or flame sensor?
    What parts was changed.
  • Joseph Lillie
    What parts have been replaced?
  • 61 Answers
Great, if you are not skilled in working on this type of appliance the best thing you can do is to call a professional out. Be careful in picking a service company, there are a lot of dishonest people out there. Try to get a reference from somebody in the construction trade that you trust.
The Next question is do you have carbon monoxide detectors in your house?
Click the blue word Carbon monoxide site for more information. It could save you and your family's life.
If I can be of more assistance, please post back.
Do not hit accept if you can not leave 100% good feedback. Customer satisfaction is very important to me.
Thank You for your time.
Accurate Joe
Posted on Dec 01, 2008
Coleman evcon furnace
Did you clean the pilot orfice?? It has a very small opening about the size of a hair. You may have to use a needle to open the opening....Are you getting gas to the pilot orfice assembly from the Gas Valve when you set it to Pilot?? If not then check the pilot adjustment screw on top of the gas valve at the pilot tube. CW decreases flow.
Nov 17, 2013 | Heating & Cooling
For sensor if you mean thermocouple that sits in the pilot light I say this is usually the problem. The thermocouple needs to heat up to a preset temp before it will allow the gas to remain on. Does the pilot light stay on? If so make sure you turn the gas knob to on from pilot/light
Oct 15, 2013 | Heating & Cooling
I have a few issues with an old probably dinosaur Coleman Presidential III 7995a-856 Heating unit. I've had 3 different repairmen look at it and they're clueless. The main pilot will light and stay lit...
if the pilot is clean and and strong then this should play on to the thermocouple , i take it you have changed the thermocouple , and the connection is good at the gas valve , then if this going out could be 1, powerunit on gas valve not holding at thermocouple connection
2. Hole in heatexchanger blowing out pilot when blower comes on
I take it the pilot stays on untill fan comes on and keeps going out , I would think about not putting any more money in to this and get new if sounds as the heater has had its day ,
Dec 17, 2010 | Coleman Heating & Cooling
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
I have a EVCON furnace DGAT070BDC. I replace the igniter control, the gas valve and the thermostat. Same problem continues: glow stick works, then the pilot lights works.The igniter control clicks...
You may have a dirty/rusty burner that is clogged or your gas valve
manifold pressure setting may be too low. Normal manifold pressure
is 3.5 inches water column on natural gas furnaces. ( 1 psig is equivalent to 28 inches water column). Pull and clean burner. Also
check and clean pilot assy. including flame sensor (if present).
Please let me know.
Oct 24, 2009 | Coleman Heating & Cooling
Bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
Jul 22, 2009 | Bakers Pride FC-616 Gas Single Oven
I have a coleman evcon and the gas keeps shutting off
The click noise you hear is the magnet inside the valve dropping out. Which means, the voltage that energizes it is low or interupted. Possible, weak pilot flame, bad thermocouple or bad secondary limit switch. This limit switch is located left of the main control. made of ceramic. It can also be a bad gas valve...
Mar 23, 2009 | Coleman Propane Forced Air Heater...
Mobile home furnace
you probably have a bad thermostat if it wont shut down id replace the thermostat first and then have the thermocoupler checked...replace the thermostat
Aug 20, 2008 | Heating & Cooling
Heating & Cooling Logo
249 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
