When pluging mp3 player into usb socket computer crashes BSOD the problem seems to have occered since insalling and uningstaling buffalo pc card
  • 404 Answers
Hello Urwin, looks like your Mp3 is using more than 5 volts and overloading the u.s.b. power supply. Has it got its own power? if so is it fully charged?
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Posted on Nov 27, 2008
I have a toshiba 8gb how do i transfer songs from my computer on a mp3 disc to my usb that is pluged into a usb on my computer
Just insert your USB to your computer,and copy the songs you want to the USB disk, itis ok?
Nov 01, 2011 | iLO (2 GB) MP3 Player
Mp3 crashed
can you connect to pc (USB)..if yes do can (in my computer, click on it) you see the mp3 files (or at least have all the mp3 on the pc already) come on say yes you have all the mp3 files on pc...Yea...(well if not this is the time to copy all the mp3 files to a temp file on pc)..ok thats done...go back to the mp3 (my computer) look for all the mp3 (hidden also) software...we are going to copy this to another folder on the pc (call it temp 2)...once this is done go back to my computer / mp3 player right click format yes format the mp3....okay it....it will yes we know erase all...this done.. go to temp 2 and copy the software back to mp3 and then copy all the mp3 files back on to it....disconnect from pc...mp3 should be like new again enjoy your crashed mp3...
feel free to rate the help
May 25, 2010 | Sony Walkman NWZ-S616F MP3 Player
My 8GB Sansa seems to have crashed
Hi.
You need to update the Firmware of your Mp3 Player.
To do that try to follow this guide:
Sansa e250 MP3 Player Updating Firmware Guide.
Good Luck.
Nov 03, 2009 | SanDisk Sansa e250 MP3 Player
Dissapeared songs
My guess is that the crash caused damage to the file system. This corruption may or may not erase the songs, but the only way to recover from such a crash would be to reformat your mp3 player which will result in erasure of all the songs in it. Formatting it will reset it to factory defaults and you should be able to reload your mp3 player and rock on!  Good Luck!
Feb 27, 2009 | RCA OPAL M4001 MP3 Player
Usb cord
Plug the Mp3 player to a diffrent USB Port and reboot the computer it should work
Aug 04, 2008 | Philips GoGear HDD1830 MP3 Player
How to insall sansa e260 mp3
My same player did not come with the CD. Depending on which program you use to get your music on your player, the CD is not needed. Try connecting your sansa to your computer and open whatever program you use for your music.
Jan 01, 2008 | SanDisk Sansa e260 MP3 Player
Workıng only wıth pc
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Dec 24, 2007 | iRiver X20 MP3 Player
MP3 Sansa m250: Crashes on certain files
Firmware upgrade needed
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Nov 26, 2007 | SanDisk Sansa m250 MP3 Player
INOVIX IMP-1112 MP3 crashing my computer.
sounds like bad news - if the flash (update to firmware) failed during update, the item is more than likely dead. Warranty return possible? Can you try another usb device on that same pc? just to verify the usb ports are working properly and supplying proper power to the devices.
Aug 26, 2007 | Inovix iMP-20 MP3 Player
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
