Question about Tappan TGF320 Gas Kitchen Range
Oven won't lite
Gas oven won't lite can smell gas when you turn to bake
broiler and stove top work fine
please help thank you
  • kimbarpescud May 11, 2010
    my home filled with gas when oven igniter failed, Is this known to build up enought to blow up?
    Sergeant:
    Champion:
  • 338 Answers
You have a bad ignitor. it may light up a little but it is not getting hot enough to light the gas. replace the ignitor
Posted on Nov 27, 2008
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Stove top and broiler work Oven won't heat
the way to check this is to first see if ignitor comes on or put an amp clamp meter on it. the ignitor needs to draw 2.8 amps or more to engage the gas valve. if it doesnt lite or draw any amps at all. check voltage to bake ignitor. it will be the ignitor most likely. but the gas valve or control could be bad.
Aug 04, 2010 | Amana AGR5835QD Gas Kitchen Range
Oven--
Is the oven working now? test to see if the broiler is working too....if broiler working and oven not you need to replace the ignitor http://www.repairclinic.com/SSPartDetail.aspx?s=t-fgf316-%3d%3di12872&PartID=12872 normally when an igniter gets old it will take a little longer to ignite the gas hence the gas smell.
Jun 17, 2009 | Frigidaire FGF316 Gas Kitchen Range
Oven will not light
check the gas valve to make sure a mouse did not chew the wires.
Jan 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Tappan TGF320 Gas Kitchen Range Logo
222 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
