Question about Canon CLC-700 Copier
Canon Copier CLC 900 problems color management settings
Hallo ,I have a Canon CLC 900,I have advanced manual for it and i need the Basic manual and I dont know where to found it.
I`m having problems setting the quality of the printed pictures.I am using Adobe photosop CS3 and i had to change the profile in the settings from adobe rgb 1998 in US WEBCOATED CMYK to get better qualitty but still not good result.I`m using the printer to transfer pictures from hot transfer paper laminator onto porcelain.Please help me how to configure the color management in the printer.I found out if I`m adjusting the pictures with camera raw and then print them I mave more bad result in the final quality printed paper
You can buy manuals for little money from canon.com. Cheers Thomas
Posted on Dec 14, 2008
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Canon clc 900 color copier comes up with e005
This error code relates to the fixing unit cleaning roller (web) having run out. You need to get it replaced.
Aug 27, 2009 | Canon Office Equipment & Supplies
The copied paper is half soiled with fuser oil.
Pull out fuser unit and remove the top. ( let machine cool down, VERY HOT!!) does the fuser web need replacing ( looks like a white paper towel roll) it has fuse oil on it. is it overflowing?? try cleaning, do not spill on floor it is very slippery and hard to clean up.
Jan 22, 2009 | Canon CLC 1000 Color Copier
Canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Problem in Color management settings for Canon CLC 900
thes machine are very old and outdated and will not function with up dated software but do a graduation adjust then do a calibarition with your firey that should get the colors back to canon spects, if you still hace the broblem then your software is not compatable
Nov 27, 2008 | Canon CLC-700 Copier
Error E004 - 0002 on Canon CLC 1000 (Switch Off and On again)
your triac is defective change it /or unplug it and then attach it that may help
Nov 18, 2008 | Canon CLC 1120 Color Copier
E072 - 0002
most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Apr 09, 2008 | Canon CLC 1120 Color Copier
Canon color laser copier
E020 is a toner feed problem to the developer. First, check for broken gears or missing teeth on all the developers. That is usually the cause.
Nov 05, 2007 | Canon CLC 1000 Color Copier
Canon CLC-700 Copier Logo
216 people viewed this question
old marine
old marine
