On my golf 2005 tdi the esp light comes on after ten minutes and the stays on until you switch the engine off. Once you start it again it will come again after ten minutes.
AnonymousApr 03, 2009
ESP light is permanently on. Appears to be a common problem especially with Touran's and Beetles! Typically costs 1.5k to fixESP light is permanently on. Appears to be a common problem especially with Touran's and Beetles! Typically costs 1.5k to fix
Lots of different things can cause this . But check the vacuum sensor on the servo pipe . The wires break on the plug . Lots of different things can cause this . But check the vacuum sensor on the servo pipe . The wires break on the plug .
You can't post conmments that contain an email address.
Need to hook up vag com to car and check to see what the sensors are reading. There my even be a code .You need to know what normal values are. Unfortunatly that means a trip to the dealer or a specialty garage that deals with euros or vws.
Hi. banging and activating the remote and pulling the handle over and over again and again helps. we open most doors this way. sometimes take 10 to 15 minutes of trying.
Although you posted this question under a 03 VW Golf and you have a MKV. The best I can do is a MKIV set up. From the rear trunk there are access ports just for this job. The right port will be just above the light housing you will find a wire harness for the right assembly. Follow the harness and it will lead you to the assembly. Once located you can squeeze the two tabs and pull the circuit board where the bulbs are installed. Push on the bulb and twist anti-clockwise then pull out of the socket.
The left should be the same procedure and it is located behind your audio components.
NOTE: It's a good idea to wipe your hand and the glass bulb, leaving oily residue will cause early bulb failure once in operation.
