Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Dishwasher short cycles and shots off
My dishwasher only runs for two minutes and shuts off, no matter what cycle it is set for. The control board was replaced and it still does the same thing. I was told that there is a series of codes that can be used to reset the board. Is this true and what would they be? Is this even the problem?
  • Doug May 26, 2009
    I have a similar problem. I tried the Test mode as indicated ( 5 presses of Heavy Wash). The code that came back was, "Normal Wash" "Clean" flashing LED's.
    Doug
    President:
  • 878 Answers
Batty, you can put the dishwasher in a automatic test mode or manual test mode. For automatic press the heavy wash key 5 times followed by the start key. 88 should show in the display if you have the digital display. It's going to check the wash motor, fill valve, drain motor, soap dispenser, vent and heater automatically. If any of these systems fail, you will get a code. The test will finish by itself. You can get the information to test the touch panel by getting the tech sheet from behind the bottom toe panel. Catriver..post back.
Posted on Jan 13, 2007
I have a kenmore elite ultra wash dishwasher, unit runs about 30 minutes then shuts off, any thoughts
Hello Forest;
My name is Peter. I am a retired field service appliance technician.
It sounds like you have a faulty electronic control board. This board starts & stops the washing, draining & drying cycles. The board cost about $96.00.
To replace the control board:
1.) You will receive the new control board in a silver anti-static bag. It is critical to ground your self by touching metal objects. Static electricity will knock out a board.
2.) Turn off the circuit breaker to the dishwasher.
3.) Remove the control panel cover. There are 2 screws on each side in the back of the cover. Remove the cover.
4.) Disconnect the electrical connector on the board. Remove the board from its housing. Install the new board and plug in the electrical connector.
5.) Remount the control panel cover.
6.) Turn on the power breaker.
There is a slight possibility the problem could be the detergent dispenser. This is an electrical component with a solenoid valve.
The electrical control board send a signal to the dispenser to activate. Lack of dispenser cycling may stop the unit.
Lets check it out: (Power Breaker is Turned Off)
1.) Remove the dishwasher front cover. There is a series of screws on the inside door holding the front cover. You may have a electrical power strip to disconnect.
2.) With the front cover removed, you will see two wires attached to metal contacts. Disconnect the wire leads.
3.) With a multi-meter, set to the lowest Ohm reading, touch the 2 meter leads together. You should get a reading of 1.0 Ohms.
4.) Touch one lead on each of the metal connectors on the dispenser. If good you should get a reading of '0', showing the dispenser is good. If the meter needle does not move or reads other than '0', the dispenser needs to be replaced.
Remember this is a long shot.
Nov 06, 2014 | Kenmore Dryers
Shuts off mid cycle
it is likely the heater or thermostat are faulty. Try to run in short cycle like rinse which works on cold water.
Apr 11, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
Why won't it run
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic board.91d0c2b1-1baa-49b9-9f99-f6a86f3b29df.jpg
Sep 29, 2013 | Frigidaire Gallery FGBD2451KB Full Console...
Dishwasher malfunction
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Jul 08, 2013 | Dishwashers
Mod DP1040XTXQ6 clean light does not come on
If your Dishwasher is stuck in a cycle check the following
Float Switch
Timer / Control
God bless you use the VOM..
Apr 05, 2013 | Whirlpool DP1040XTX Portable Dishwasher
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher does not drain...stops in cycle...no matter what cycle
HI, this is a control fault. the logic chips are malfunctioning. these chips are responsible for initiating the proper washing cycle sequences. you will need to replace this damaged control board asap.
Click here to order your new control board online.
Jun 04, 2009 | Maytag MDBH955AWS Stainless Steel 24 in....
Heating Element Won't Turn Off
Ok, this is a control fault that may be corrected by shutting the power off for 5 minutes. this will reset the chip set on the control board. plug the unit back into the socket after the 5 minute ait and check to see if the element is still on. If so, replace the control board.
May 29, 2009 | Amana ADW662EA Built-in Dishwasher
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
433 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
