The comp switches on but theres no display - Computers & Internet
  • 1 more comment
  • zhoe Nov 27, 2008
    no meant the laptopz
  • zhoe Nov 27, 2008
    its been like this since yesterday but the power is working its just the display its dark
  • Dominic
    Dominic May 11, 2010
    Is there a indicator light on the computer showing that it is on? Moreover, is there a indicator light on your display shows there is power going to it? When was the last time the computer was operating?
    Novelist:
  • 167 Answers
Your system may be in CRT mode for a external display; press the "Fn" key and the "CRT/LCD" hotkey to change the monitor mode. Furthermore, your battery could have died while your laptop was in a suspended state; removing the battery and unplugging the laptop for the power supply for 30 seconds should reset the power management system.
Posted on Nov 27, 2008
    Genius:
  • 1,250 Answers
If you are not sound on technical knowledge its better take it to the technician
    Genius:
  • 1,250 Answers
Take the RAM out of the slot then insert it again, then check
On booting up my Inspiron mini 1012 netbook it keeps displaying 'the user profile service failed the logon' and 'user profile cannot be loaded'
Try logging in on the admin acct then delete and recreate the profile. If it doesn't work you can try switching off the comp then continously press F8 while turning on the comp and choose safe mode, then do a system restore.
Mar 18, 2011 | Dell Inspiron Mini 1012 Netbook...
When you are in "comp"
The "Deg" indicates degrees are the unit used for trigonometric calculations. You can use [MODE] [5] to switch to radians or [MODE] [6] for grade. [MODE] [4] switches back to degrees. This is independent of "Comp" mode.
Jan 16, 2011 | Casio FX-260 Calculator
I have model 2271 PAG 40 it seems to be stuck in some kind of display mode. switching from comp to baro to alt.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 22, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
No display
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jan 12, 2010 | HP 2133 Notebook
Programm the machine to show my comp name and
Press the dataregistration button,when dataregistration is displayed press ok or start.When user settings is displayed press ok/start.Scroll with tha arrows untill unit name is displayed press ok and insert comp name ,press ok.To insert fax number scroll to unit tel and press ok and insert fax number.
Aug 17, 2009 | Canon FAX-L350 Plain Paper Laser
Samsung hdtv to compaq pc
There should be a setting within the comp. Is it connected to the comp monitor and the tv? Perhaps from the comp to the tv with the monitor from the comp as well? Well if so, you may need a certain setting within the comp. Check under (on xp) display properties, and then under the settings tab. Please rate!
Apr 28, 2009 | HP Compaq nx6110 PC Laptop
PROBLEM W/ CASIO fx-260 SOLAR
Sorry, but I think you misunderstood what the manual says. See the not on the screen capture.
True the sentence is not very clear, but what it means is the following:
All modes (except COMP) will have an indicator (with the appropriate labeling) displayed. When in COMP mode the COMP indicator is not displayed.
The truth of the matter is that computation- wise you have two MODES only : the general COMPutational mode and the Standard Deviation (SD Statistics) MODE. These two are incompatible because the key layout is different.
But to compute trig functions
  1. calculator must not be in SD mode, hence it is in COMP mode
  2. An angle unit must be shown on display.
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Jun 04, 2008 | Casio FX-260 Calculator
Compaq presario evo 1015v
sounds like a bad screen this might be able to be remedied by hooking the laptop straight to a computer monitor threw the ports provided in the back
also you could have bumped something loose inside like a video card if any cards or memmory comes loose this will give you black screen of death the laptop will have to opened and cards pressed down gently
theres the solution of your power supply on the laptop went out and you need a replacement
if power supply went out it doesnt hurt your comp it just makes it hard to run
May 21, 2008 | Compaq Presario 900 /1500 Series EVO...
Comp will not turn on also see lightning bolt display
Hi All,
This happens because of static energy storing in the motherboard components.
We can try power drain to resolve this issue.
Try doing power drain by taking out the battery & keep holding down the power button for complete one minute to drain out the power from the computer components. Restart the computer after putting the battery in.
Try restarting the computer only with the AC power, without the battery & vice-versa.
That should resolve the issue, if the issue persists, then you have to contact service center.
Hope that information helped you!!
Apr 16, 2008 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
David Payne
David Payne
