My computer is showing system halted - Computers & Internet
  • alok_kum_007 Dec 01, 2008
    R u guys trying to say that if I change the battery of my computer
    it will not show system halted
    plz tell me I need to know I beg of u guys to tell me & try to solve my problem.
    and plz mail me as soon as u get the mail.
  • Dominic
    Dominic May 11, 2010
    Usually happens to protect the system from damaging itself... Did you recently make system or hardware changes? Was it shut down improperly?
    Genius:
  • 1,913 Answers
The battery on the motherboard is most likely gone and doesn't save the settings. You can go to Wally World or any store that sells watch batteries and get a new one for about $2.50 or so. Then, it would keep the settings and you most likely would not have to do that. The time and date changing is a real indicator that is the problem.
Posted on Nov 27, 2008
    Genius:
  • 1,250 Answers
Try to run your system in safe mode by pressing F8 continuously during the booting process, then restore to previous date, through system restore
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
Are 2002 Aztec computers compatible
I am assuming you are discussing the 2002 Pontiac Aztec, the early crossover with the rather distinctive look. I would assume that since they were made by the same manufacturer and they used the same parts that their computers should be compatible. I can't say so for certain as you haven't provided much information, but, unless one of the Aztec owner swapped out the original computer and replaced it with an updated device, the computers should be compatible.
If you are thinking of trying to swap computer chips, I would advise you to wait and let a professional do it at an independent shop. The reason I suggest this is simple, unless you know how to access the computer chip correctly, you risk accidentally ruining it. If you handle the replacement chip incorrectly it is entirely possible that for a stray static charge to ruin the chip by blowing out a trace. Also, if you damaged the socket from which the original chip was removed then it is possible that you will not be able to reinsert the new device without bending any leads on the bottom. If the leads are damaged, then the new computer won't work.
Even if the new computer chip and the original chip were already installed in installable cases (the way most desktop computer chips are installed), it is possible that when you removed the computer, you might have damaged the receiving socket which means that when you go to insert the new computer carrier it won't work correctly because a few or many of the pins on the bottom of the board won't sit correctly.
Jan 03, 2015 | Computers & Internet
What is the difference between windows 7 editions: starter, home basics, home premium,ultimate, professional,interprice?what is the difference between service pack 1 & 2???pc
Since October 31, 2013, Windows 7 is no longer available in retail (except for the Professional edition preinstalled):[6]
Windows 7 Starter Windows 7 Starter is the edition of Windows 7 that contains the fewest features. It is only available in a 32-bit version and does not include the Windows Aero theme. The desktop wallpaper and visual styles (Windows 7 Basic) are not user-changeable. Microsoft originally intended to restrict users of this edition to running three simultaneous applications but this limitation was dropped.[7]This edition was available pre-installed on computers, especially netbooks, through system integrators or computer manufacturers using OEM licenses.[1][8][9] Windows 7 Home Basic Windows 7 Home Basic was available in "emerging markets", in 141 different countries.[10] Some Windows Aero options are excluded along with several new features.[1] Home Basic, along with other editions sold in emerging markets, include geographical activation restriction, which requires users to activate Windows within a certain region or country.[11] Windows 7 Home Premium This edition contains features aimed at the home market segment, such as Windows Media Center, Windows Aero and multi-touch support.[12] Windows 7 Professional This edition is targeted towards enthusiasts and small-business users.[1] It includes all the features of Windows 7 Home Premium, and adds the ability to participate in a Windows Server domain.[1] Additional features include support for up to 192 GB of Random-access memory (increased from 16 GB),[13] operating as a Remote Desktop server, location aware printing, backup to a network location, Encrypting File System, Presentation Mode, Software Restriction Policies (but not the extra management features of AppLocker) and Windows XP Mode.[1] Windows 7 Enterprise This edition targeted the enterprise segment of the market and was sold through volume licensing to companies which have a Software Assurance contract with Microsoft.[1] Additional features include support for Multilingual User Interface(MUI) packages, BitLocker Drive Encryption, and UNIX application support.[1] Not available through retail or OEMchannels, this edition is distributed through Microsoft Software Assurance (SA).[1] As a result it includes several SA-only benefits, including a license allowing the operating of diskless nodes (diskless PCs) and activation via VLK.[14] Windows 7 Ultimate Windows 7 Ultimate contains the same features as Windows 7 Enterprise, but unlike the Enterprise edition, it was available to home users on an individual license basis.[1] Windows 7 Home Premium and Windows 7 Professional users are able to upgrade to Windows 7 Ultimate for a fee using Windows Anytime Upgrade if they wish to do so.[1] Unlike Windows Vista Ultimate, the Windows 7 Ultimate edition does not include the Windows Ultimate Extras feature or any exclusive features as Microsoft had stated.[1] All editions will receive Mainstream Support (new features and bug fixes) until January 2015 and Extended Support (security updates) until January 2020.[15]
Dec 08, 2014 | Computers & Internet
How do i turn off the HDD
What happens when entering the sleep mode is the drives will be turned off and the present state will be kept in memory until awakened. While the system is active the power scheme will prevent the drives from idling down after so many minutes with the never turn off setting applied.
With the turn off drives after the default 20minutes of inactivity that doesn't mean all drives turn off at the exact same time. I've never come across any reference for changing the power plan option for individual drives. But I can point you at the guide for the power plan settings with one instruction on drive settings to apply prior to entering the sleep mode.
hope that helps if not let someone here know.
Oct 03, 2014 | Computers & Internet
How to convert desktop hard drive to external hard drive?
See this... http://voices.yahoo.com/converting-old-computer-hard-drive-into-external-1481521.html
Jul 13, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
How to fix computer problems for free
First make certain you have a virus program running and do a full scan. There are free ones around, most use AVG. You can get pop-up blockers, or look at internet options and select block pop ups.
Visit the following website called Black Viper. Follow the instructions and that should speed up your computer.
http://www.blackviper.com/
Mar 07, 2014 | Computers & Internet
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
Mouse and keyboard have no power
If your mouse and keyboard work properly with another computer or laptop the problem could be :
A) if devices are USB :
- defective USB port : chose another USB port;
- USB port inactivated in BIOS : check and activate;
- motherboard defective : replace motherboard.
B) if devices are PS/2 :
- damaged PS/2 ports : buy a PS/2 to USB adapter for your mouse/keyboard or buy USB mouse and keyboard;
- motherboard defective : replace it.
Oct 04, 2009 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
