Question about Indesit Washing Machines
Indesit W1XE127 showing default display F-01 after 7 minutes of operation. What's the problem?
  • Indesit Master
  • 3,463 Answers
Hi.
Error code F01 normally indicates a faultry motor triac.
Unfortunately you are going to have to call an engineer.
Please leave feedback.
Thanks.
Posted on Nov 27, 2008
Error code F 01 shows up now & again on display clock and loses time when washing is this a motor triac fault
F01: Triac Motor short circuit
- Check for water leaks that may affect connector J9 causing the relevant contacts to short
- Check the motor terminal block (possible problems due to chemical effects of work residuals on the contacts which may cause short-circuiting)
- Replace Card
The answer may be inaccurate because it is not specified appliance model
Dado
Mar 16, 2015 | Indesit Washing Machines
Indesit wie147 displaying F-01 code - not rinsing or spinning.
Is your machine pumping the water out? If not, thats why it wont spin. It cant do it with too much water in
Oct 21, 2011 | Indesit W 123 Front Load Washer
Indesit w1xe127 how to remove the drum ,so as to renew the bearings
on this machine u cannot change the bearings. the entire drum has to be replaced. if the machine is under 5 years go through the 5year parts warenty, will cost you aprox £100. otherwise the machine is not worth repair.
Jul 11, 2011 | Indesit Washing Machines
I purchased a panasonic dp-2330 trying to set it up to my network but i need a key operator code it is not the default "0000" any way i can reset it?
Enter service mode (Function, Original Size "Ledger", 3) simultaneously. F1 will then show on display, press 7 then Start key, F7 mode will then be diplayed. 01 is the key operater id code and will show current id code. Touch 01, sreen will then let you make changes, select change and input your 4 digit code then select ok. Your finished, exit service mode.
Feb 01, 2011 | Panasonic Workio DP-2330 Printer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Indesit evolution 1200 showing (F 01) Does anybody know what this means????
F01 means short circuit motor triac.
Check all connections on motor, motor plug and leads, and the control module.
Hope this helps.
Thankyou.
Nov 27, 2009 | Indesit WA 125 Front Load Washer
How do i change the time on my samsung prostar 816 phone?
  1. Enable technician programming mode
    • Press "#" - "PROGRAMMING" is displayed
    • Dial "20" - "MMC ENABLED" or "MMC DISABLED" is displayed
    • Dial the password (default - 1234) - if wrong password is enter "ERROR" is displayed
    • Dial "1" to enter program mode
    • Press "#"
  2. Press "#" key - "PROGRAMMING" is displayed
  3. Dial "55" - the display shows "YY MM DD W HH MM" and then the current date is displayed
  4. Enter the new date
    • YY = Last two digits of the year
    • MM = Month (01 - 12)
    • DD = Day of the month (01 - 31)
    • W = Day of the week (1 -7 day of the week begins on Monday & ends on Sunday)
    • HH = Hour (Use 24 hour clock)
    • MM = Minutes (0-59)
  5. Press "#" - new date is saved
Jul 24, 2009 | Samsung Prostar 816 Phone
F-01
F01 is indicating a short circuit motor triac, this is part of the control that controls the main motor. You have no option but to call Hotpoint (indesit) and book an engineer as it is something you can't do youself..Sorry , but that is your course of action.only
Plz rate my solution.
Thanks
Dec 29, 2008 | Indesit W 123 Front Load Washer
How too change time
Norstar Merdian Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Cancel
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS Time
  • Press "FEAT".
  • Press "*".
  • Press "*".
  • Press "266344" (CONFIG) or "23646" (ADMIN).
  • Enter password "23456" (ADMIN) or "72787" (SCPLUS).
  • You will see "Terminals & Sets".
  • Press "Next" five times.
  • Press "Show"
  • When you see "Hour", press "Change" or "Next" to skip.
  • Type in the hour using military time as a 2 digit number.
  • Press "Next".
  • When you see "Minutes", press "Change" or "Next" to skip.
  • Type in the minutes using a 2 digit number.
  • Press "Next".
Date:
  • When you see "Year", press "Change" or "Next" to skip.
  • Type the year in 2-digit format.
  • Press "Next".
  • When you see "Month", press "Change" or "Next" to skip.
  • Type the month in 2-digit format.
  • Press "Next".
  • When you see "Day", press "Change" or "Next" to skip.
  • Type the day in 7-digit format.
  • Press "Next".
  • When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
  1. To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
  2. Enter password (default = 266344) - display should read "Terminals & Sets"
  3. Press "NEXT" 5 times - display should read "Time and Date"
  4. Press "SHOW" - display should read "Hour:___"
  5. Press softkey "CHANGE"
  6. Enter hour - display should read "AM OK or Change"
  7. Select AM or PM
  8. Press "NEXT" - display should read "Minutes:___"
  9. Press softkey "CHANGE"
  10. Enter minutes
  11. Press "NEXT" - display should read "Year:___"
  12. Press softkey "CHANGE"
  13. Enter year
  14. Press "NEXT" - display should read "Month:___"
  15. Press softkey "CHANGE"
  16. Enter month
  17. Press "NEXT" - display should read "Day:___"
  18. Press softkey "CHANGE"
  19. Enter day
  20. Press "NEXT"
Sep 15, 2008 | NorStar T7316E Corded Phone
Indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
Nov 13, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
672 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
