Question about 2wire HomePortal® 1800HW Router (1000400212000LNR)
Unable to get laptop to connect to the internet.
I have just purchased a Netgear WGR614 wireless router. I have installed it as per the CD Rom supplied however, when i try to connect to the internet I am unable to do so. The laptop recognises that it is connected to the router but does not allow me to gain access to the internet. The laptop is a Dell Inspiron and it is wi fi enabled and used to work on the Belkin router I used to have. The main desktop pc is working ok and allows me to connect to the internet. Does anyone know what I can do to get connected? My ISP is Virgin and I connect through cable broadband.
Regards,
Ken
I have resolved the problem by doing a system restore. I set the computer to a previous date and this seems to have sorted out the problem. I guess that I may have had a software confliction.
Many thanks.
Posted on Nov 28, 2008
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Can't get wireless connection
try locating the wireless switch of your new Acer. It might be accidentally turned off thats why no available wireless network found in range
Jun 11, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
I lost the installation cd for my netgear 54mbps wireless router WGR614 V6
you just need to open a web browser and type http://192.168.1.1 (default username is "admin" adn default password is "password"). it'll prompt you now for the router's setup page where you can setup your internet connection.
hope this'll help you and if you have other concern just ask me
ciao!
Jul 08, 2008 | NetGear WGR614 Wireless Router
Wireless connection
When you got your router, you should have recieved a setup CD. run it ant it will set everything up for you.
May 20, 2008 | NetGear DG834G Router
Netgear wireless router
I'm trying to change my Nat settings from Strict to open so that I can play Xbox live more efficent. I tried using port forwarding but it didn't work.
Apr 03, 2008 | NetGear WGR614 54Mbps Wireless Router...
Installation software
http://kbserver.netgear.com/products/WGR614.asp
Copy and paste the above URL into your browser and download manual and software directly from thier server.
Feb 08, 2008 | NetGear WGR614 Wireless Router
Netgear router WGR614
try using "admin" for the user and "password" for the password. I have this very same router and that was the default settings for me.
Nov 19, 2007 | NetGear WGR614 Wireless Router
2wire HomePortal® 1800HW Router (1000400212000LNR) Logo
120 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
