Question about Ovens
I have a Thermador MEMW271ES wall oven that displays error code
First, the oven displays error code "e118." The internal fan won't turn off. The oven cannot be used. we've turned it off at the breaker repeatedly. Thermador was no help at all.
  • 1314 Answers
SOURCE: thermador oven secd272bs error code after install
check your owners manuel for code meaning and how to clear if its new call for service some can push stop reset or clear
Posted on Dec 31, 2007
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
marked
  • 6487 Answers
SOURCE: Thermador C302U error code
From my experience when there is a power outage, This is likely to have wiped out the control board on your oven. I see it all the time after storms. If a storm comes through, I get a ton of phone calls about control boards not working anymore or doing crazy stuff. If resetting the breaker has shed no light on your situation. I would recommend replacing the main control.
Also when you get this fixed, plug the stove into a surge protector of some sort. This will decrease the chances of a power outage doing damage to the oven control.
Hope that helps........
Posted on Jun 28, 2008
plnolte
  • 62 Answers
SOURCE: My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
Posted on May 12, 2009
localwonder
  • 6784 Answers
SOURCE: Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Posted on Dec 08, 2009
How do I fix an F34 error code on a single Thermador wall oven?
If the fan is blowing, then likely a sail switch problem. If switch ok, we see control board failures that cause this also. If need be, we can rebuild the boards for you. See
Limited supply of refrigerator boards for sale Used in Whirlpool...
Sep 15, 2015 | Thermador Ovens
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
Hbl8450 E118 error
E118 indicates a comma error. You could check for loose connector block or plug on ribbon cable. Best course of action is to call a Service Engineer.
Sep 19, 2017 | Bosch Ovens
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
Thermador oven sc272t f-c code I have a F-C code on the oven and it beeps continunually. Do I need to call a repairman?
Hello, welcome to FixYa.
Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display.
Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately).
In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units.
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 23, 2011 | Thermador SC272T Electric Double Oven
Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
May 20, 2011 | Thermador C301U Electric Single Oven
CODE F64 WHEN TRYING TO USE THE BOTTOM OVEN.
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Mar 29, 2011 | Thermador C302U Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
Ovens Logo
586 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
