Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Just had a Kenmore bottom freezer refrigerator delivered yesterday. Worked fine when installed. Now have had ER FF message for 24 hours, Fridge isn't cold. How can I reset this, or do I need to call Sears for service after the holiday after we have to throw away everything inside? HELP!!!
  • Charles Caldwell May 11, 2010
    Are there three digits before and a "dot". These three digits determine who manufactured your appliance. Sears/ Kenmore do not manufacture there own appliances. If you could give the three digits it would help in determining what is wrong.
    Sergeant:
    Champion:
  • 311 Answers
Call sears- means freezer fan not running. Unit will not work without it.
Posted on Nov 28, 2008
Kenmore 795.7130 bottom freezer model, loud noise when fan kicks on. from what I have read it is the evaporator fan. how difficult to change?
We had a problem with a loud noise when the motor turned on. Didn't know what it was but after a week or two, the noise went away and the Refrigerator was no longer cold (even though the freezer was fine). At this point, instead of temperatures showing inside the refrigerator read out, there was an error code: ER FF. The circulator motor was no longer working. This I read was due to an ice build up which binded the motor. We shut off the unit for 24 hours to defrost it and it worked fine after that. Do this before calling a repair man for service.
Oct 23, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG25960ST Er ff This error came up today. Turned it off four four hours and then back on. Worked OK for about an hour and then error message again. Turned it off again for about four hours, turned back...
Try a complete 24 hr defrost, the sensor probe is probably encased in ice. 4 hrs is not enough time to defrost. If this does not cure it, it is probably a fan problem.
Apr 17, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Error message ER FF - refrigerator is not cooling as a result
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
I have code error "err ff"
I also had an "eR FF" message. I discovered that the fan inside the freezer compartment was locked up from accumulated frost. I unplugged the refreigerator for about 6 hours and left the freezer compartment door open so it could completely defrost. So far, it's been running smoothly (and more quietly!) for about 24 hours now. (My fingers are still crossed).
Feb 18, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge not working
Error code ER FF and evaporator fan makes loud noise
Aug 15, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Error message er if
Hi. Error FF is your Fresh Food Fan. Otherwords, the evaporator fan motor has failed. You should replace the motor and motherboard. You may get by just replacing the motor. Sears doesn't manufacture the refrigerator. They just pay extra to have Kenmore put on it. Its the manufacturer that needs to back their equipment. If you bought it from Lowes, you can't hold Lowes responsible for the ongoing issue. They sell the same refrigerator. Anytime this model refrigerator displays an Error code, unplug it for 5 miniutes and replug it. Sometimes it was a computer misfuction. Good luck! Mack
Dec 28, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
177 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
