Question about GE GSS25JEMCC Side by Side
Ge gss25jemc ice in door keeps freezzing up
The small flapper door on the in door ice dispenser does not close all the way. It causes frost to build up on the dispenser. I only get crushed ice, even when selecting cubes. Is there a spring on the door that keeps it closed? Is it hard to replace? Thanks for the help. Dennis
  • 1 more comment
  • denaleah Sep 20, 2008
    I have the same problem and now the water dispensor won't stop running when I remove the glass and water goes everywhere!!
  • kgallego32 Sep 23, 2008
    flapper door stays open which causes tons of frost buildup inside.
  • Anonymous Mar 17, 2014
    The flap in the door is in the open position. there is supposed to be a spring or gear that keeps it closed when ice is not being dispensed.
  • 237 Answers
Flapper door diagram is here, you can see how the spring, etc. work to hold the door closed. http://www.partselect.com/Schematics/GE/00113173i04.gif As for the crushed ice, (item 384) on the next diagram shows the little lever that lifts the side rod on the bin (item 329) to decide if cubes or crushed comes out. The solenoid (item 383) can get frozen up and not move. Take a look where screw (item 371) is, that little square window is where the device that lifts the rod is. Take a hair dryer and heat that area REAL good to melt the frozen solenoid mechanism. Test it every now and then by holding the door light switch off and pressing the cubed selection & lever. You should hear a very loud "clank" as the solenoid pull in to lift the rod on the bin.
Posted on Jan 13, 2007
Remove and clean the rod that goes into the center of the solenoid, Note that to get access, depress the two holes on the undeerside of the top of the dispenser with a small punch or screwdriver tip.
Posted on Sep 18, 2007
I am trying to install a new heat motor on a frigidaire refrigerator model frs26zrg. I am having frost build up on front side of ice maker, assuming its from flapper not closing all the way.
I assume your frost is at the front of the ice bin? If so, your correct. Room temperature air is leaking in to a 0 degree environment and causing frost build up. First, I would see if the ice door closes 100% without spring by pressing your finger on the door. I've had bad ice doors that were warped. Next, inspect supporting rod and spring and make sure they look ok. An eye test should suffice. Next, without heat motor, the spring should keep door shut 100%. See if that helps, good luck!
Sep 18, 2015 | Frigidaire Refrigerators
Ice Dispenser keeps getting frosted over and not dispensing ice
The problem your having is that the door in the dispenser chute isn't closing completly and warm air is coming in, clashing with the freezer and the moisture in the warm air freezes and collects right there in the chute causing the ice build up. The more common parts that may cause this is the door flapper being bad or damaged, flapper soleniod, which helps the flapper doofr get a good seal, and electronic board on the dispenser itself.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 24, 2012 | GE Refrigerators
Gs5shaxtl01 ice dispensing door does not close causing melting/refreezing resuling in ice buildup and failure to dispense through outside door. Was there a recall? Was there originally an electric heater...
The part that keeps the flapper door closed can break which will let frost to build up. The door itself can break in two. My repair man used crazy glue to fix mine and was done in 5 minutes.
Oct 12, 2017 | Whirlpool GS6SHAXLS Side by Side...
Ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost buildup on area where ice comes out of the ice bin with frost also on the inside of door chute
The flap door where ice is dispensed is warped letting warm air into the freezer causing the frost build up. You must replace the flapper - a $5 - $7 part but not too difficult to replace. I find the flapper last only about 2 years and frost problem reappears. Forget about a "weak heater".
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
GE GSS25JEMCC Side by Side Logo
317 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
