Question about Dryers
I have a kenmore dryer model #66902690, last night I went to start it and had to hold down the start button for several seconds. My husband said it smelled bad last night too. This morning I pressed the button, it started, then stopped and won't start now. Any ideas?
5 Suggested Answers
  • 90 Answers
SOURCE: Kenmore dryer won't start
Bad thermal fuse
Posted on Jan 05, 2008
  • 686 Answers
SOURCE: Clothes smell burndt after drying in a Kenmore gas dryer
Rule number one NEVER EVER use the top of your dryer to stack piles of clothes while in use. That is the main reason why dryers over-heat. Also clean out the exhaust tube to the exterior.
Posted on Feb 26, 2009
maddogsteve1
  • 18 Answers
SOURCE: dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
Posted on May 25, 2009
SOURCE: Kenmore dryer start button not working
when I push the start button on my kenmore dryer it will not start and the drum will not turn.
Posted on Dec 21, 2009
Why did Kenmore series 110.60202990 dryer stopped working after power outage?
check electric box, termo fuse on air duck (white 2 wires normally blue)
Jan 05, 2015 | Kenmore Dryers
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
Dryer does not start Model 66902690
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 26, 2010 | Kenmore Dryers
Hesitates to start
your motor bearings are either getting dried out or the motor start cap is getting weak
Sep 18, 2009 | Kenmore 72802 Gas Dryer
My whirlpool duet control lock light is on and the machine will not do anything. I have held the end of cycle button for several seconds and even turned the breaker of all night hoping to "reset" it.. no...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 29, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer won't run unless you manually hold down the "on" button.
im not sure which dryer you have but ther is a electonic control on some start buttons if you dont have that the motor is bad i would jump start swich for now it will last a long time
Jul 05, 2009 | Kenmore 64952 Electric Dryer
Dryer just sits and hums
if you push the start and it just humms it is a bad dryer motor to weak to kick on,to confirm this have sombody hold the dryer door button in and turn the drum when you push the start button,if it jump starts you know it's a bad motor-mike
May 05, 2009 | Dryers
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Open Questions:
Dryers Logo
108 people viewed this question
Top Dryers Experts
