Question about New World G90m Gas Double Oven
Fan does not always start immediately
Fan normally starts eventually but can take a little time.
Model No. 200504055
Serial No. 40623349
  • New World Master
  • 3,463 Answers
The fan motor bearings have probably dryed out with heat of the oven, if you remove the fan blade you can spray it with lubricant, this will probably solve the problem short term, but eventually you will have to replace the fan motor.
Posted on Dec 19, 2008
How to use without the fan force?
You have to modes on your oven. One is normal and the other is convection or speed cook. The normal mode does not use the fan.
Post make, model number and serial number for more information. J
Jun 06, 2015 | Ovens
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
Why does gas oven make a humming noise and shut off after 20 mins
Don't take risk and call the technician.
Aug 25, 2014 | Ovens
Hotpoint BD 42 Oven, main oven fan turning slowly and oven is not heating up to temperature
Hi you will to have a tester , start off by checking power at the outlet , if you have the 220 volts then we need to check the elements inside the oven, you may a have a bad element and a bad fan , after checking power get bacl to me , also need model number and serial number
Dec 01, 2011 | Ovens
Hi The fan is this oven dosn't always work! Sometimes if you give it a gentle nudge it will start to spin other times it just wont spin at all & some times it works perfectly! any ideas on how to...
You need to change the fan motor. These motors are not very powerful and wear in the bearing can cause this effect. oiling the bearings is only a tempory fix and you will eventually end up changing the motor.
Jan 22, 2011 | Electrolux EOB5610 Ultrafan Electric...
This oven has always had a loud fan noise when it was on or during cooling off. A couple of times lately I have turned it on and it has only had a quiet hum. I've turned it off and turned it back on a few...
Anonymous, we're sorry for the inconvenience. We would like to discuss this further with you. Please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with your name, address, a phone number and best time to reach you along with your model and serial number.
Oct 21, 2017 | Whirlpool GMC305PRS Stainless Steel...
The fan on my circotherm double oven does not come on straight away any more
Assuming the fan does start eventually, then I would say that the fan bearings are starting to fail.
You could try spraying the bearings with WD40,, but long term, you are probably going to have to replace the fan motor.
Hope this helps with your prob.
Nov 28, 2009 | Neff B1432 Single circotherm plus Electric...
We have a Westinghouse oven model WHG 645 KNG serial 90911136. It takes so long to heat up. I leave it on for 10 minutes then put on the fan. It takes ages before the gas seems to ignite at the back of the...
This is a problem with the ignitor. We have had this replaced 3 times in 10 years and the service technician says each time that he'll be back within the next 3 to change it. They actually haven't charged us for the parts the last 2 times because Westinghouse obviously know that it is a piece of $&@# .
Aug 31, 2009 | Ovens
Delayed auto start
In some units this is a normal function. Wait for about five minutes and see if the fan turns off. If not, please let me know and I'll find a solution for you.
Jan 21, 2008 | Dacor ECS130 Epicure Electric Single Oven
Jenn-Air built in oven Model W188-C, Serial # 210764UC approx 1987
Big oops, Millwood. Shut power to the unit immediately and wait a day or more for it to dry out. If it works then, fine. If not, you've got a learning experience installing a new pad.
Dec 07, 2007 | Jenn-Air JJW8230D Electric Double Oven
New World G90m Gas Double Oven Logo
206 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
