Question about GE (PSS26MSRSS) Side by Side Refrigerator
Bad Smell in Fridge
Strong fishy smell persists in GE side by side despite thorough cleaning, first with water & baking soda - then a few days later with soapy water.
Emptied appliance and smell still there.
Tried several on-line suggestions - boxes of baking soda in emptied freezer and fridge, then coffee in shallow dishes in both freezer and fridge, then finally baking soda and vanilla extract mixture.
Couldn't locate source of odor anywhere, even after removing back panel.
HELP!!!
  • KS2000 Feb 10, 2009
    I have the same problem with our GE, and I have tried the same cleaning techniques. I was curious to know if there is a filter in the vents in the back wall that could be replaced or taken out and cleaned.
    Thanks
    KS
    Novelist:
  • 157 Answers
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
Posted on Dec 01, 2008
My fridge smells fishy. It is perfectly clean and i have not had fish in there.
Bacteria will cause the smell. Make sure it is cold and put a box of baking soda open inside the fridge. It will absorb the odors. They sell baking soda with a mesh side specifically for your fridge.
Jun 06, 2011 | Samsung RS2530BSH (25 cu ft) Side by Side...
Can't get the fishy smell out of fridge....used baster and put water with baking soda down drain under bottom freezer bin... took back off...cleaned compressor Hotpoint HSS25GFPA
I was watching tv the other day and they said if you want to get rid of awlful smelly smells use newspaper. Put newspaper in the frig and close the door. Let set for like two days and repeat. The newspaper will absorb the smell somehow because of the chemicals it has. It works great with pickle jars. no kidding.
Mar 23, 2010 | Hotpoint HSS25GFP Side by Side...
GE side by side refrigerator smells on the outside!
Mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section . Too much bleach and the smell of bleach would be circulated by the fan to the room , so be sure to add water .
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fishy smell in camper fridge
They freon used is mainly amonia,best thing to use is bleach put in spray bottle mix 70 percent water and 30 percent bleach squirt entire fridge let soak then wipe clean let air out as much as possible!!!! :)
Jul 19, 2009 | Zanussi ZEBF277W Bottom Freezer...
Frisdge/freezer and ice smell
I had a side by side refrigerator with an Ice maker from Sears. The ice it makes smell fishy so bad that I could not use to drink with anything else but throw away to the plants. So I unscrewed the ice maker . It is not that bad, but quite simple to take it out. I noticed rusted pieces of metal generating strong fishy smell. I could not get rid of rust with soap, detergent, oil so I wrap it in plastic bag then screw it back into the refrigerator. Screwing back the ice maker. Voila. The smell is going away. The ice is good. Pina Colada and Daiquiri here we go .
Jan 24, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Odor in GE side by side Fridge
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a homeking fridge freezer and there is a really bad smell coming from the fridge which is not because of food. i have emptied the fridge and thoroughly cleaned the fridge but the smell is still...
Hi, i have the same problem with my Homeking fridge. Because it is a frost free firdge, there is a little resevoir at the back, with a small little tube leading from the base of the fridge into it. There are 2 screws holding it in place. Unscrew these but keep the resevoir firmly in place as the nasty parmesan-type smell is actually stagnant water and you really really dont want to spill it. Empty it and then what i did was bleach and anitbacterialise the resevoir tray and the little tube thing. Though I had the problem solved but now it is doing it again less than 2 months after this, so I'm going to contact the people who sold it to me. This is how you get rid of the smell though!!
Good luck
Laura
Aug 14, 2008 | Refrigerators
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Smelly Fridge
Try putting an open can or two of coffee inside. My mother's freezer had gotten unpluged and it was full of fish. She put cans of coffee inside and shut the door a couple of days later she took them out and the freezer did not stink anymore. Hope it works for you.
May 05, 2007 | GE GSS25JEMWW Side by Side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,091 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
