Question about iLO DVDRH04 DVD Recorder
Dvd ilo 4
Yes i pres the menu botton and in the picture i read if you not want to see the dvd picture you press yes accidental i press yes right now i put the dvd to see the screem and i not see nothing but and heard the picture please if you cant help me becouse the dvd is new, thanks.
    Problem Solver:
  • 7 Answers
Yes yu is accidental and see the scream the new dvd yes right now and heard the picture.
Posted on May 29, 2007
Wanting a code to make my dvd player region free
1. turn de dvd unit on
2. open the dvd disk player and leave open
3. Pres 0 4 times
4. the region menu appears
5. change region
6. press pause to save and end
7 you are region free
Dec 26, 2010 | LG HT503SH DVDDivX USBHDMI 51 51 system...
I have a (cyberhome ch-dvd 300) dvd player and changed setup menu now lost video cant see to change back is there a reset code or something
I wish I could find the website that gave all the repair hints for this DVD player, but I downloaded the info, and can no longer find the site. Here is what it says with regard to your symptoms. I hope this helps. I have done all the mods the site suggested, but continue to have difficulty with the remote, tray opening, etc. I have 2 machines and used to love them, but frustration has taken it's toll. Recovering from a condition with no TV picture
Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
"To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter.
On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
1. With the unit stopped, press Setup on the remote.
2. Press the Right Arrow Once.
3. Press Enter.
4. Press the Down Arrow 2 times.
5. Press Enter.
6. Press the Up Arrow 2 Times.
7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
To change the Parental Control setting on the CH-300 use the factory password of 3351. For the CH-400 use 1379.
Nov 02, 2009 | Televison & Video
I NEED HELP GETTING THE DATE TO PRINT ON MY PICTURES. I HAVE A SONY DSC W80
Here are the steps to follow to set date and time to display on every picture you take
1- Turn the dial to play
2- Press Menu
3- Press the Okay key ( it is the middle botton in the back side just SE of menu botton
4- press right arrow key
5- scrole down and high light date/time and press right arrow key
6- now you need to high light day/time or date and press okay botton as above.
Now if you take any picture or video, date or dat/time will be on the pictures you take
Take care and good luck!!!!!!!!
Jun 11, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
I changed some video imput and now i cant see anything, only audio
1. Press FUNCTION repetedly until "DVD" appears in the front panel display.
2. While holding down rewind botton, press FUNCTION.
The output signal is changed to interlace format.
Apr 23, 2009 | Sony DAV-FR10W System
Side BY Side Picture On TV Black And White
Try holding the stop button and the DVD dubbing button at the same time and waiting about 3 seconds. I had to do this twice, but it solved my problem.
Feb 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Dont know how to change dvd with out useing skip botton
Press the Display button located in the middle right of the remote. This brings up a menu on the tv that shows the dvd number. Press the right arrow button to get to the number. You can then enter the number of the dvd you want. After you have entered the number press the enter button. This will cause the desired dvd to load. You press the Display button again to tun off the menu.
Nov 22, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Setting the time on my iLO DVDR05 Recorder
1 Press Setup to enter the setup menu.
2 Press the up/down keys to select GENERAL, press enter, Use up/down keys to selet clock setting. press enter.
3 Move to the field to be edited using the up/down keys
4 use up/down keys to increase or decrease the value of the field.
5 To exit a field using the right/left keys
6 Press return to exit the clock settings menu.
Select time format from the menu and press the right arrow key. Use the up.down key to pick hour mode(12hr or 24 hr).
Thats the instructions from my manual.
Mar 18, 2008 | iLO DVDR05 DVD Recorder
Ilo 32-hd
ILO TELEVISION TURN ON AND OFF BY IT"S SELF, IF I HOLD DOWN THE VOLUME BOTTON IT COMES ON,LET THE VOLUME BOTTON GO NO PICTURE
Aug 29, 2007 | iLO 3200 32 in. LCD Television
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
I cant get back to s-video mode.....:(
Sep 23, 2006 | iLO DVDR05 DVD Recorder
iLO DVDRH04 DVD Recorder Logo
77 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
