Question about Asrock ALIVENF6G-DVI Skt AM2 Nvidia NF6100-430 onboard 256MB shared VGA 8 channel audio mATX Motherboard
Little or no connectivity
I just replaced my motherboard, RAM, and processor. The computer was tested on the internet at another site and it worked. My internet here works on my laptop so I know it works as well. When I ran ipconfig it gives me the default (auto) addresses for windows XP. The computer is recognizing the newtowork adapter for the motherboard in the hardware tab and when tested it says it works. I have comcast. I have tried everything but I still dont have internet???
  • 96 Answers
Hello. If you're not using an ethernet cable make sure you have the proper usb drivers for the modem and that you modems 'ID' (mac ID) has been registered with comcast. What your pc is probably registering is the fact that it is acutally hitting the comcast servers. All that means is that you're really getting out into the world, but since comcast doesn't have your modem on file it will not let it through. you may also want to recheck your firewall settings, and reset everything in the line. this means modem, any routers, or hubs, your pc and any other pc you may be networked with all at the same time then power them up one by one. don't login until everything is turned on. if you are networked this will pose a few different problems
Posted on Nov 27, 2008
MY ASUS P6T DELUXE TURNS ON BUT THE C-MOS SCREEN DOESNT SHOW.....
First thing to check with a desktop computer problem, is the Power Supply.
No sir,....cannot ASSUME power supply is good, because LED's light up, and fans spin.
1) If ALL the LED's were lit up at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor (CPU) can use 51 to 125 Watts of power.
Just depends on what Processor it is.
Intel Core i7, model 950?
http://en.wikipedia.org/wiki/List_of_Intel_Core_i7_microprocessors#.22Bloomfield.22_.2845_nm.29
Up To 130 Watts. (TDP. Thermal Design Power, or Thermal Design Point. Whichever you prefer )
Exceeded the spec's I stated.
Power Supply with a weak voltage rail, will have enough power to turn the wimpy little LED's on, and spin fans; but will NOT have enough power to turn the Processor on.
How to know?
Test the 3 main voltages coming out of the Power Supply, with a multimeter set to DC Voltage;
Or,
Temporarily substitute the Power Supply, with a KNOWN to be good, Compatible one.
Borrow from a working computer. Then you can diagnose if this is the problem; and can put it back in the working computer.
The motherboard you have needs at least 150 Watts.
CPU = 130 Watts
Each ram memory module = 15 Watts (DDR3 Sdram)
Harddrive and optical drives around 25 Watts each.
Fans 2 to 3 Watts each.
Your CPU requires 3 ram memory modules at least. 6 can be used.
So........
150 + 130 + 45 + 50 + 6 = 381 Watts.
Bare minimum is 400 Watts, and you should have a 500 Watt power supply. Need at least 10 percent over what is needed; but why play around? 500 Watts.
http://www.asus.com/Motherboards/P6T_Deluxe_V2/
http://extreme.outervision.com/psucalculatorlite.jsp
Have a multimeter?
(An economical model can be purchased for as little as $5 to $12)
1) ALL Orange wires are 3.3 Volts
2) ALL Red wires are 5 Volts
3) ALL Yellow wires are 12 Volts.
ALL are DC Voltage.
In comparison two D cell flashlight batteries produce 3 Volts DC.
ALL Black wires are Ground wires,
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
(Your SMPS is of the ATX technology)
Need guidance in performing this? Post back in a Comment.
Also:
When checking a desktop computer, after checking power; and this does no good;
Have ONLY the Processor, processor fan hooked up, and Ram Memory.
That means disconnect EVERYTHING else.
Harddrive, (Power and data cable), optical drive, (Power and data cable), computer case fans, (NOT processor), Card Reader cables, Front Panel USB cables, etc.
All you are trying to do at this point, is see if you can pull the BIOS Setup screen up.
If so then add Harddrive, and computer case fans.
[ Note* This is a fast test. BIOS Setup screen comes up, turn the computer off.
CTRL key, ALT key, and Delete key AT SAME TIME.
You don't want to overheat the motherboard. Primarily the Northbridge chip, and Southbridge chip; of the motherboard chipset.
You're just performing a fairly fast test ]
Intel Core i7 requires THREE ram memory modules, at least.
People have used two, but do not apparently understand the Nehalem technology, and using an Intel Core i7.
http://www.hardwaresecrets.com/article/535
Go to Page 2, middle of page.
For additional questions please post in a Comment.
Regards,
joecoolvette
[ By the way,............if your computer comes to life..........RUN!
It's an inanimate object! lol!
(Day the computer became alive!
See how it took over it's owner's mind, and made him search the internet for the rest of his life!
What evil lurks in a desktop computer's mind? (Processor)
ONLY the SHADOW KNOWS! )
http://www.youtube.com/watch?v=2rqd8Oa-sA4
Mar 16, 2013 | ASUS P6T Deluxe Motherboard
Tip
HOW TO RESOLVE A MAJOR PROBLEM ON A DESKTOP COMPUTER
MOST DELL OPTIPLEX HAVE SIMILAR PROBLEMS,OF EITHER NOT COMING,BEEPING AND NOT CONNECTING TO NETWORK.
NOT COMING:unplug the system disconnect the HDD connector,and power it on again if problem persists,remove the RAM/MEMORY and reinsert it again,if it doers the same thing,leave the ram and unscrew the fan and have a feeling of the processor to see if its hot,if the processor is not hot,replace the it with a similar type and test again,if it does the same thing....JUST BE SURE ITS THE MOTHERBOARD.
BEEPING:this is mostly caused by MEMORY/RAM,NOTE its going to beep for SIX times,reinsert it and test run it,if beeping continues replace the ram and here you go.
NOT CONNECTING TO NETWORK:its two way either the your network cable nor the port,if problem persist replace the cable or test with another system entirely,if it does the same thing,place order for the motherboard.
Do as follow and let me know how it helps.
Thanks
ADOGHE OBEHI
obehiadoghe@yahoo.com
on Jun 29, 2010 | Computers & Internet
PowerEdge 2850 server beeps as soon as it is turned on - 3-2-1 beeps format. What has failed?
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 03, 2011 | Dell 3.0 GHz Second Processor for...
Hi,my computer has stopped working and just beeps at me. mother boardis a Microstar P4m266-8235. Please Help......Thank You
This problem could be due to carious problems.
1) Your motherboard is faulty.
2) Your Processor is faulty.
3) Your RAM chip/s are faulty.
Firstly, you will need to unplug your computer and open it up. Then you need to locate the RAM which looks like this:
Remove one piece of RAM (assuming you have more than one piece) and try to start the computer again, then if it doesn't work, remove the other chip and reinsert the chip that was first removed and try to power up again.
If it works, then one of the RAM chips were faulty and you will need to replace them.
If the computer still does not work, then either your Motherboard or Processor are faulty.
You should then buy a new motherboard which isn't too expensive (be sure to buy a motherboard that will fit in your computer and will also be able to handle your processor.). Place the motherboard with the RAM in to the computer case after removing the old motherboard. Then carefully remove the processor from the old one and put it in to the new one.
Be sure to re-insert any cables that you have unplugged from the old motherboard in to the new one. Then try and power up once the machine has safely been closed again.
If the computer works, the motherboard was faulty. If it still does not work, then your processor is faulty and you will need to buy a new processor and install it.
Alternatively, you can take the computer to a repairman who will test the various components which will save you the hassle of doing all of that work and it will also save you the cost of having to buy new RAM and a new motherboard if in fact it is actually your processor that is faulty.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Jan 10, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
Sir, I have a Dell optiplex GX110. At the motherboard there is a long brown slot in which a board of 4 expansion slots has been pluged. The first problem was that I had removed the heat sink from the...
When you inserted a test probe into the slot and you saw a spark, then you have short circuit a component on the motherboard and have done a major damage to the motherboard.
You need a new motherboard, most desktop cases have standard mounting holes, you may be able to purchase a motherboard from other manufacturer to fit in the Dell.
Oct 09, 2010 | Dell Optiplex GX110 (2909T) Motherboard
Would not boot Processor pins appear undamaged
  • Check for shorts and overloads inside computer by removing nonessential items such as extra controller cards and IDE/ATAPI devices and turning the computer on to see if it starts to boot. Leave the motherboard, power supply, RAM or processor. If the problem goes away, there was a short or overload with one of the components that you just removed or one of those components is faulty. Replace each of those one at a time until you isolate which is causing the problem. If the problem still occurs after removing the nonessential components, the problem has to be with the motherboard, power supply, RAM or processor.
  • Remove the processor and RAM and reinstall them to make sure that they are installed correctly.
  • If the problem still persists, swap the RAM with known good RAM. In addition, test the suspected RAM in another known working system.
  • If the problem still persists, swap the processor with a known good processor. In addition, test the suspected processor in another known working system.
  • If the problem still persists, swap the motherboard with a known good motherboard. In addition, test the suspected motherboard in another known working system.
  • Feb 25, 2010 | Computers & Internet
    Will hellgate london work on my pc
    Looks like your graphics card may be a little weak.
    Also check your ram.
    Here are the MINIMUM requirements.
    OS: Windows XP with SP2 or Windows Vista
    * Processor: 1 .8GHz or faster (2.4GHz for Vista)
    * RAM: 1GB or more (2GB for Vista)
    * Video: DirectX 9.0c/10 compatible device w/ 128MB RAM or better and Pixel Shader 2.0 support; requires NVIDIA GeForce 6200/ATI Radeon 9000 chipset or greater
    * Audio: DirectX 9.0c compatible device
    * Disc drive: 8x DVD or faster
    * Hard drive: 6 GB or more free space
    * Input: Keyboard and mouse
    * Internet: Connection required for multiplayer
    Nov 17, 2007 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
    Asrock ALIVENF6G-DVI Skt AM2 Nvidia NF6100-430 onboard 256MB shared VGA 8 channel audio mATX Motherboard Logo
    112 people viewed this question
    Top Asrock Computers & Internet Experts
    David
    David
    Computer Links
    pankaj rautela
    pankaj rautela
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
