Question about Samsung X05 Notebook
Need ide cable for samsung x05
Need ide cable from hard drive to mother board and where can i get 1 if not from u please help
Posted on Feb 02, 2009
Hi Intel mother board D 845EPI After replacing
-make sure that the hard drive cable (IDE cable) is plugged-in correctly. It is possibly inverted.
Dec 18, 2010 | Intel Desktop Board D845EPI Motherboard
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
PCI IDE slot does not detect hard drive
Check if power cable to the HDD is connected properly or not.If it is connected then check the jumper settings on HDD.
Mar 12, 2009 | ASUS P5GD1-VM Motherboard
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
I wanted to know whether ASUS A7S266-VM/U2 will support seagate 7200.10
M/Boards support all makes of hard drive
Are you sure you connected it correctly
The wide ribbon cable that goes in the rear of hard drive should
1) Be connected to M/board in the No 1 connector with the stripe on cable to the No 1 pin
2) the stripe on cable should go next to the 4 pin power plug on hard drive
Also ensure your BIOS is set to Auto detect of driives
Aug 30, 2008 | ASUS A7S266-VM/U2 Motherboard
Motherboard fails to see Hard Drive...please help
Sounds like you lost an ide channel, swap the ide cables around, primary to secondary and secondary to primary. and see if it recognizes the hard drives and not the cdrom.
I lost an IDE channel and had to install a sata hard drive or run the hard drive and cdrom on the same ribbon. If you run HD and CDROM on same ribbon set both to CS (cable select)
Mar 23, 2008 | Dell Dimension 4600 PC Desktop
How do i install a second writable disk drive???
aloha...this can be done, IF your computer has the expansion capacity. what kind of computer are you using?
Mar 17, 2008 | AOpen : CDRW 52x32x52 Beige Color Retail...
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Acer hard drive
Hi, the problem is one hard drive ie the 1/3 one is a SATA hard drive, the other is IDE.
to set them both up you need to do this,
Connect the IDE Hard Drive using the IDE cable like before.
With the Acer Hard Drive you need a Sata cable cost about a £1 from any shop.
You connect the sata cable from the hard drive to the motherboard, but on the motherboard you are looking for a small red connection same size as the cable, SATA is on most motherboards for machines that are just over a year old.
Hope it helps.
Have a nice christmas
Dec 10, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Samsung X05 Notebook Logo
61 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
