Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Television is "locked"
My 1 year old was playing with our TV remote control. Now the TV is locked. By this I mean that it says across the screen in green letters "LOCKED". Sound is OK, but no picture. TV is a SONY Trinitron KV-25C3B. Thanks in advance for any help!
  • Adamson Nyau
    Adamson Nyau Mar 17, 2008
    MY TV IS A SONY TRINITRON MODEL 21SDF22.THE CHILDREN PLAYED WITH THE REMOTE AND ALL IT SHOWS ON THE SCREEN IS A PADLOCK.HOW CAN I UNLOCK IT? HAVE FAILED.
I dont have the answer, but do have the same problem and just wondered whether you had solved the problem....our son is 13 months old and I think he is the one who caused the tv to be locked too !!
Posted on Aug 26, 2007
Sharp Aquos RC Control Lock and Operation Lock Out
When all else fails read the owners manual page 35:
"• To unlock the buttons on the remote control by using the
touch sensor panel of the main unit (see page 25):
1 Press MENU to display the MENU screen, and then
press VOLl/k to select "System Options".
2 Press CHs/r to select "Operation Lock Out", and
then press INPUT.
3 Press CHs/r to select "Off", and then press INPUT.
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
Apr 05, 2012 | Televison & Video
Television "locked"
Hello can you please post the brand and model of the television so we can find unlocking instructions.
Jun 18, 2008 | Televison & Video
My tv is locked and asking for a an unlock code. I have never had a lock code on the tv since i bought it several years ago. How can I reset or bypass this feature. BTW mt TV is a 48-50" projection...
Hello
I thinks that you have its original remote handset with you now, and posts this solution. If you don't have it, either buy a new original remote handset or try to get it from any of your friends and relatives, who owns the same model of Mitsubishi Tv, you have now; only to unlock it. After unlock, you can use any other remote control.
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
OK.
Sep 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I was playing with the remote, now tv won't turn on, have I put it in some sort of "locked" mode?
I had the same problem my 4 year old soon played with the remote and not more TV.
Aug 14, 2010 | Sony KP-53V80 53" Rear Projection...
Locked TV have no remote, tv won't turn on
You're going to need the remote to fix this one. If you have any other GE or RCA tv's you can try it. Most of the remotes that are produced within a few years of your television will probably work. When you get one the instructions are: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 09, 2010 | RCA TruFlat 27F520T 27" TV
TV locked with blue screen
Try resetting the TV to factory settings thusly:
Turn on the TV. While holding down the RESET button on the remote
control, press the POWER button on the TV. (The TV will turn itself off, then
back on again.) Release the RESET button.
Owner's manual available here:
http://www.docs.sony.com/reflib/docget.asp?manualid=9635&template_id=1&region_id=1&DL=
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Large Black Bar across one channel only Polaroid T.V.
Turn off CC1,2,3 or 4. You are seeing a Closed caption screen with either no data or encoded data. Usually the blank CC's are 2,3, or 4.
Jul 27, 2008 | Polaroid 1720-7 Remote Control
Remote control code
depending on the remote you have from rogers but the newest remote has 5 device's across the top we call it a 5 button there is a 3 and a 4 and a fat 5 button that is the old pvr remote all are pretty much the same in setting up easiest way is on 5 button remotes select the device ie. tv pres and hold setup untill light flashes 3 times enter 9-9-1 the with the tv on press ch+ button untill tv turns off once tv is off press setup to lock in the code test it by pressing tv then pressing power should turn tv back on if not repeat previous steps untill you get the right code some tv models are not compatible with the rogers remote 3 and 4 button pretty much the same except insted of a setup button you have to press and hold tv and select at the same time untill light flashes 3 times press 9-9-1 then press tv button untill tv turns off press select to lock into place
Dec 29, 2007 | GRIFFIN TECHNOLOGYTotal Remote-PDA Remote...
Thick multicoloured stripes accross the screen
Some condesator gone bad.. remote control IR eye needs 5V voltage but now it's not there so i think you need to replace bad condesator.
May 30, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Locked TV
hold down the display button for a few seconds
May 14, 2006 | Jensen Q2749J 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
164 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
