Question about Jenn-Air JMC7000 Microwave Oven
Jmc 7000 adw microvave oven nothing on
Checked the circuit breaker to make sure it was on
  • William Miller
    William Miller May 11, 2010
    Could you please clarify what your symptom is?
    Your subject line got cut off after the word "nothing"
4 Suggested Answers
  • 5 Answers
SOURCE: jenn-air microwave JMC 7000 ADB has no power
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Posted on Jan 04, 2008
SOURCE: No power on Jenn-Air JMC 7000 ADB Microwave
I have the same problem every time I use the oven for a long time and then use the micro.
Solution is simple, yet unbelieveable.
This is a toggle switch. It is located on TOP of the oven box.
It is almost impossible to reach...but once reached, all you have to do is push it and it resets the micro.
1-remove the "frame" around the micro.
2-pull the micro out (use 2 people) far enough so that you can reach your hand - or I use a wooden yardstick- to toggle the thing. It is VERY tiny.
Posted on Mar 24, 2008
MicrowaveSvc
  • 9098 Answers
It's either the fuse or the thermostat on the magnetron.
You can download the service manual here.
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 02, 2008
I have a neff B6774N0GB combi oven. Activated the hot air button and it has tripped the circuit breaker. Fan element examined and looks perfect. Oven is isolated from other appliances
The hot air function uses a great deal more current than the other functions. Check the tag on the oven for current requirements, and check the rating of the circuit breaker in use. If the breaker is rated lower than the ovens rated maximum current draw, it will trip under the load. If the rating of the breaker is above the ovens maximum current draw, and there is nothing else plugged into that circuit, the breaker may need replacement.
Sep 14, 2016 | Neff Microwave Ovens
MICROWAVE OVEN "DAEWOO" MODEL KQG-868G PROBLEM :
There should be 3 'fuses' inside a microwave. The 'line' or monitor fuse, the magnetron fuse or TCO (thermal cut out) and the cavity temp fuse. I'm trusting that you have verified that the outlet is 'hot' first. Be careful !!
Nov 03, 2013 | Microwave Ovens
Internal fan came on and is running when microwave is not running
might be sticking relay.
or the magnetron tube is soo hot that it kicks the fan on (but it happens rarely).
check the circuit where the relay connected to blower.BUT be sure microvave capacitors have 5000 volts in them.Short them first other wise forget to open it.
thanks
please rate my work
Sep 08, 2011 | Microwave Ovens
Microvave not heating the food
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Feb 24, 2011 | Magic Chef CMV1000B Microwave Oven
Maytag MMC 5000 ADW built-in microwave...about 10 years old. Fuse blows and circuit breaker pops every couple of months...what causes this? I keep replacing the fuse, but obviously something is wrong. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There is a high draw of power in the high voltage part...probably the capacitor is going bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 10, 2010 | Microwave Ovens
Will not heat up
1. Make sure the controls are set properly,that the oven selector switch is set correctly and that the temperature
switch is set to the desired temperature where applicable,make sure the oven timer is set to manual.
2. If nothing else on the Range,Oven or Cooktop is working then
1. Check the circuit breaker or fuse.
2. Test for power.
3. Test the oven elements.
4. Test the oven thermostat.
5. Test the oven selector switch.
Feb 03, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
prototech@usa.net
Apr 29, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Dec 18, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-air microwave JMC 7000 ADB has no power
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
43 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
