Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
My trimmer starts but after warming up stops and wont start again
I have a McCulloch trimmer that when it starts and warm up (5 to 7 minutes) it stop and wont start again. You leave it to rest for a day or two and the same thing occurs.
What can be done to solve the iisue?
Thank you.
  • 65 Answers
After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used
Posted on Nov 30, 2008
Bypass valve stuck?
Yes, I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Aug 14, 2012 | McCulloch FHH18A Electric Pressure Washer
What is the correct choke position (close/half open/open) AFTER successfuly starting a chainsaw on a half open? (Mcculloch M4620)
Once started and warmed up, then replace choke to run position. The choke will be completely open (non-restrictive).
Contact us
User manuals
McCulloch Service
May 27, 2012 | McCulloch Garden
I have a gx610 that runs nicely for about 3 minutes to 5 minutes then it stops FAST. Like very sudden. It wont start or crank again until a few minutes pass then it cranks, and a minute later or so it...
Check for plugged fuel tank vent. Vacuum builds up then fuel stops. Also check if it has a low oil presssure switch that might cut it off (check the oil level). This engine has many variations so finding a specific problem is not easy.
Apr 25, 2011 | V-Twin Horizontal OHV Engine with Electric...
Kawasaki khd 600A hedge trimmer just wont start.it runs for a second and stops
Bit late to help the owner of this question and yes it could be a carbie issue but also check the idle speed. If it has dropped out of calibration and is idling too low it will start then stop. Try starting with some throttle, keep it running if you can until it warms up then let the throttle go back to idle. If it stops check to see if opening the idle screw solves it.
Sep 24, 2010 | kawasaki Garden
1986 Nova: engine stops while standing and at low RPM. OK before I got rear ended. Next start up: would not idle without revving. Next startup: OK but died while driving home; kick started without any...
Is the choke opening up all the way after it warms completly up ? and have you checked the fuel lines to the gas tank they might have got pinched in wreck.
Jan 02, 2010 | 1986 Chevrolet Nova
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Car wont work after the initial warm up die down situation
Crank sensor or module. Check fuel pressure too.
Jul 03, 2009 | 1999 Pontiac Grand Am GT
Trans shifts very hard after 5 minutes of stop and go traffic
A reason for hard shifting could be a problem with many things with various degrees of seriousness. It could be your ATF( automatic transmission fluid) is low or broken down and old. This would cause the hardness and the reason for stop and go traffic effecting it. Another possibility is your transmission is just shot, and the timing gears inside are worn and not properly shifting at the correct RPM causing a **** during shifting.
Some possibilties, not all!
~Lucas
Mar 27, 2009 | 2003 Buick LeSabre
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
442 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
