Question about Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
I have an early 70's Gaffers and Sattler wall oven that won' work. This has happened before and we figured out that the timer was set in a position that wouldn't let the oven get hot. Normally I can mess with timer while continuously feeling the element so that when it starts getting warm I know. This time I can't figure out the setting it wants. Any ideas would be wonderful!! The light does work, so I know it has power to it. Thank you so much!!!
  • Anonymous Jan 04, 2009
    I have a gaffer and sattler wall oven that will not heat. Light works and warming oven stays on. It is a 1977.
    Top Expert:
  • Ariston Tech... Master
  • 81,285 Answers
The most common failure in any electric oven is the heating element.
Posted on Jun 20, 2017
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: My hotpoint BU72 oven works find but the clock
If you are not able to reset the timer from flashing display regardless of what combination of buttons you press, then I am afraid the only solution is to replace it, they are expensive.
Suggest you try pressing the first 2 button on the left, and the last button on the right at the same time if you have not already done so, this may solve the problem.
Posted on Feb 09, 2010
SOURCE: HEATING ELEMENT GAFFERS & SATTLER BUILT-IN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Posted on Nov 22, 2010
SOURCE: My Ariston oven FV 271
No solution I'm afraid, just exactly the same problem, have you managed to fix yours?
Posted on Dec 17, 2010
How do I turn off the timer on my gaffers & sattler wall oven?
Try rebooting the oven; unplug it for 90 seconds, or flip the circuit breaker off for 90 seconds, then back on.
Apr 17, 2016 | Ovens
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
I have a 1965 gaffers & sattler wall oven with the oven on the top and the broiler on the bottom. It began having issues lighting even though the pilot light was on. Now the burner doesn't light up at...
My Mom has a 1965 Gaffler & Stattler Mark 21 wall mount oven, it had the "Same Problem", People may tell you that the flame switch is no longer avalible but I found a universal fit flame switch at Applance Parts Center, I took the old part in and had it matched up, with a minor modification to the thermal sensor mounting bracket, "drilling a larger hole and lightly crimping it", it's a perfect fit, "problem solved". You may want to try cleaning the pilot light area with a small wire brush first, if that dosn't work try a jumper wire on the two terminals of the flame switch, if that works then replace the flame switch.
This operation can be done without removing the oven from the wall mount, just remove the two screws from the panel at the inside rear of the broiler, you will find the flame switch behind the panel it has two screws two wires a thermo leed and a sensor tip that goes up to the thermo sensor mounting bracket above the pilot light, the thermo sensor mounting bracket has one screw and a nut behind it, you will also need to remove one end of the 1/4" pilot gas pipe in order to remove the thermo sensor mounting bracket, When your done puting it back togather, check for gas leaks using soapy water in a spray bottle, a dish soap solution works great, also check your vent pipe connections.
After I cleaned the dust and grease out of this old thing, the 45 year old clock and timer started working again.
My Mom is very happy, try and find new oven to fit the cutout and vent, we saved a lot of $$$,
"Good Luck".
Nov 18, 2010 | Ovens
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
Dec 22, 2009 | Ovens
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven Logo
594 people viewed this question
Top Ariston Technologies Ovens Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
jb_ab1
jb_ab1
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
