Question about General Electric 30 in. Profile PP950 Cooktop
Pp950 stove top F code
Had this top for about a year. When I use the large element with any others for any length of time I get this F143 or something like that and it locks out the cooktop. If I reset it can use the other burners. This has happened twice last year.
It is holiday time and we cook a lot.
3 Suggested Answers
SOURCE: Clicking noise on cooktop even when all burners ignite
Jsut a guess - see this solution: http://www.fixya.com/support/t119696-constant_clicking_when_turned
Posted on Mar 31, 2007
Controlfrk
  • 304 Answers
SOURCE: Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Posted on Aug 31, 2009
We have a JennAire model CP220W-C01 cooktop. We use the old coil type heating elements. There was a flash and smoke from the right front element. A repairperson replaced the connector, only to have it blow...
Unplug the element from the receptacle and then disconnect the receptacle from the point where it plugs into the stove. Now, carefully, turn on power to this heating element. If nothing happens then you have removed the likelihood of a problem in the large portion of the stove's wiring. Next, plug the receptacle cable back into the stove without connecting the heating element. Again, carefully turn on the power to the heating element in question. If there is no spark then the cable, connector and receptacle are ok. If it does spark, replace the receptacle and cable assembly. No spark, then inspect the heating element where it connects to the receptacle. Look for melting or signs of damaged insulation that would allow for a "dead short". If you see damage to the element then replace the element. No damage, clean the connections with a toothbrush, and plug the element back in and turn on the juice. If it sparks again, replace the element. Good luck and be careful. Don't attempt any of this if you are inexperienced in working with electricity. 220 Volts can cause death or serious injury... just the flash from an arc can cause blindness and burns.
Nov 05, 2013 | Jenn-Air Cooktops
Need calibration procedures for my ge cooktop pp950
Fred,
Did you get an answer? Having the same problem!
Thanks!
Apr 21, 2013 | GE PP950SMSS
I have a jenn air stove top/grill. I'm not sure exactly how to set up the grill. I have a few parts and I'm not sure what to do with them. I have the 2 grill tops to cook on, the heating element, which...
Your doing it right. It just isn't a very good design. I'm betting that you also wonder if you have it plugged in all the way too, as it feels a bit loose at the plug end also. And, it isn't just because it is imbalanced -right? Don't worry it is exactly how Jenn Air made it.
As far as the other big pieces of metal - I think your friend may be onto something.
Good Luck
Jan 13, 2010 | Cooktops
I cannot adjust the temperature on the elements of my stove top.
Hello Skyemahan,
I work on stoves with various problems all the time, and have never encountered a problem exactly like yours. You may get other answers, but here's my two cents worth: When I don't trust a stove, I replace it. Period. Hopefully, your's is old and you're ready for a new one. A new stove is much cheaper than a house fire.
Best Regards, --WoobieDog--
Jul 10, 2009 | Cooktops
Burner Elements on Electric Kenmore Elite 790 Stove
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 02, 2009 | Maytag MEC5430BDS Electric Cooktop
Stove top keeps turning off
if your breakers have become week they may trip with a lesser amp draw.sooooo if they trip right when you turn on a switch on the range, then it is a short in the range.if it trips after your using it abit its your breaker.hope it helps God bless ,tom
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
Stove problem - outer cirlcle of an expandable element not working
You will need to call a professional these are very complicated and not easy to service, there are no fuses either. It will most likely be the element itself that has failed and they are not cheap. It also could be the switch too however it will take a person very familiar with schematics to properly diagnose it. Or you could just replace the element and switch yourself and that would most likely solve it.
Dec 26, 2007 | Cooktops
One unit show fault code F153
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
General Electric 30 in. Profile PP950 Cooktop Logo
48 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
