Question about HP Compaq d530 SFF PC Desktop
HP D530 SFF, PSU replacement
I need to replace the PSU. I am having difficulty in removing it from the case to fit the new one. I have tried to locate a maintenance manual on the WEB in order to take the right steps in sequence but without success. Any help appreciated. I also wish to fit a new quieter Fan. Advise on removal of the old would be helpfull.
Ha just had the same problem myself, infact its easy. You must remove the rear plate of the machine - just 2 screws in the upper corners hold it on. the you can wriggle it off and slide the psu out the back. just make sure you untangle the power cables before you pull too hard, or you'll br replacing the mobo too :) hth f
Posted on Jul 28, 2007
    President:
  • 2,961 Answers
You need to find out the motherboard make or a serial number. As this may have a slocket type fitted processor(on it's side) and makes you limited with fan types etc.
Posted on Jan 11, 2007
  • andrew pester
    andrew pester Jan 11, 2007
    sorry ignore last, wrong post, appologies.
  • andrew pester
    There should be 3 or 4 screws on the outside of the case holding the psu in and sometimes 2 securing screws along the body, and it should just slide out of the casing, as when you buy a new one it will be fitted exactly the same, as they are normally universal.
    Just ensure that you get the same size as some compact pc's have a mini psu fitted.
Rom battery replace
If you are refering to the CMOS battery, Open the case, look for a button battery, remove and replace. Take a look at HP support: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph04375&lc=en&cc=us&product=94878
Jan 15, 2013 | HP Compaq d530 SFF PC Desktop
How do I replace a power supply in a hp compaq d530 desktop? From the front, behind, top, or bottom?
the top cover should slide off from the back end remove any swrews at back before sliding cover
Mar 05, 2011 | HP Compaq d530 SFF PC Desktop
Replacing the CR2032 on the d530 sff still result in internal clock resetting itself after a few days
In that case I suggest there is a processing fault on *********** board. You could try re-seating the uProcessor in its socket.
Jan 05, 2011 | HP Compaq d530 SFF PC Desktop
I have an hp d530 cmt motherboard with tray & would know if it would fit in an hp xw4100 case. I have not been able to locate a d530 case.
Most mother boards are loosely speaking "one size fits all". The newer the board the smaller generally. You will have to offer it up and see. It may mean you have to move a couple of pillars.
So long as the PSU leads fit, it sholud be OK.
Dec 15, 2010 | HP Compaq d530 CMT PC Desktop
HP d530 sff - Hard Drive Sounds Like it Will Take Off!
Its caused by services that update or monitor the drive. Intel motherboards seem to cause HDD to operate with a lot of noise
Aug 17, 2009 | HP Compaq Business d530 PC Desktop
Hp compaq d530 400 watt power supply
You will not find a power supply for this case. Why would you want to upgrade such an old computer? Get yourself a new one with amply power for your needs. If you are one that upgrades regularly, get a standard case with standard components that can be upgraded without the hassle of replacing proprietary form-factor compnents.
Aug 02, 2009 | HP Compaq d530 SFF PC Desktop
Replacing power source
I removed the cover, drives, motherboard, and the back plate and then the power supply just slide out the back of the case.
Aug 02, 2008 | HP Compaq d530 SFF PC Desktop
HP Compaq d530 SFF PC Desktop Logo
583 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
