Question about Microsoft Limited Edition Halo 3 Wireless Headset for Xbox 360
Headset wont turn on
It just stopped working. i plug the charge cord in nothing i hit the power button nothing. the light will flash for a split second but still nothing
  • 146 Answers
You change the battery's? Did you step on the headset ?
Posted on Nov 27, 2008
Afterglow Wireless Headset Blue Flashing mic light
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
Jan 23, 2014 | Radio Communications
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
Jan 03, 2014 | Computers & Internet
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Cs55 connects but has no sound on headset
The compatibility setting, in almost 100% of the cases, should be set to "1".  You can find it on the side of the base, it's a little turn wheel that will turn if you stick your thumbnail in it and twist.  I have seen one instance on the Cisco IP phones that requires the compatibility setting to be on 5, so try that as well.
If you have a lifter installed, make sure that the short telephone cable that comes out of the back of the headset's base unit is plugged into the handset port of the telephone (where the handset coily cord is normally plugged into).  You would then plug the handset coily cord into the front of the headset base unit.  Make sure you have that configuration, and try again.
Finally you can try a re-set.  To do this you should lift the headset off of the charging base, make sure the green light on the top of the base is off (the headset is off), and then do the following: 1. Hold down the mute button and the call answer button at the same time. (The mute button is the black little wheel on the top of the headset itself.  If you use the tip of your finger to push that straight in, it will mute the headset) 2.  Keep holding both buttons down until the green light below your thumb on the headset flashes for 2 consecutive series. 3.  Let go.  Wait about 20 seconds then try answering.
If this doesn't work, try a re-subscription: 1. Place the headset back on the charging base. 2. The two microphone volume adjust buttons on the back of the BASE unit should be pressed together.  This will start the red light and the yellow light blinking on the front of the base unit. 3. Hold the mute button down while the headset is still on the charging base.  Hold it down until the red light stops blinking. 4. Disconnect the power to the base so that the red light and yellow light turns off. 5. Plug the power back in after about 5 seconds of it being disconnected and make sure the red light on the front of the charging base is now solid and the yellow light is flashing. 6.  Pick up the headset and try again.
May 07, 2009 | Plantronics CS55 Wireless Headset
Plantronics Pulsar 590A headset won't charge anymore.
I too have the same problem as jessehaye154, does anybody know of a solution?
Apr 10, 2009 | Plantronics Pulsar 590A Wireless Headset
Plantronics cs70 nc stop working
Make sure that the power is connected to the headset.  You can tell it's connected because there will be a red solid light on the left side of the front of the charging base.  Check the power cord for any frays and make sure it's plugged into the wall.  If it is, then try the following:
A system reset:
1.  Lift the headset off of the base. 2.  Make sure the headset is turned off.  The green light will not be on on the base. 3.  Hold down the minus button at the same time as the call answer button on the headset.  Hold them down for at least 10 seconds.  An orange light on the headset will flash several times.  It should go off when you let go of the buttons.  If the orange light stays solid, push the minus button once. 4.  Put the headset back in the charging cradle.  Leave it for 30 seconds.  Lift it back out of the cradle and try using it again.
Oct 01, 2008 | Plantronics CS70 Wireless Headset
My jabra bt250 headset wont turn on
check my post on solution 4 on this link, my headset still working 1 month after i boosted it.
Aug 14, 2008 | Jabra BT250 Consumer Headset
Initial charge
Does anyone have an answer to this. Or just return it.
Oct 30, 2007 | Palm (3206WW) Wireless Headset
Microsoft Limited Edition Halo 3 Wireless Headset for Xbox 360 Logo
411 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
