Question about Philips bSure SV2 Brilliance Multimedia Projector
Bsure sv2, powering up then turning off.
New bulb, lamp life 12 hours, can turn the projector on, stays on for 30 seconds then slowly goes to black. Standby is set to off.
SOURCE: Philips bsure SV1 , LCD multimedia projector
Pl try M. R. nterprises Mumbai +91 22 23802513/23856204
Posted on Nov 25, 2007
SOURCE: Philips Bsure sv1 lc3131
This indicates the bulb has blown and needs replacing.
Posted on Apr 17, 2008
SOURCE: Philips bsure sv1 projector
press menu, then picture, select mirror, then choose the "Aa" which appear to be the right way up for you, then press ok.   Done!!
Posted on Jan 04, 2009
SOURCE: philips bsure sv1 projector
try plugin a computor or dvd in so it picks up a signal.
Posted on Jul 26, 2010
  • 8 Answers
SOURCE: Lamp blinks on bSure XG1
Same here with the bSure SV1. Want to find solution as well.
Posted on Jan 15, 2011
  • 1591 Answers
SOURCE: Phillips bSure XG1 LC3141
Try opening the unit and cleaning the LCD and lens, and also clean the outer lens- it sounds like this unit may have been stored or used in a smokey environment!
Posted on Jun 20, 2011
0 characters
1 Points
The bulb dont turn on
Projector Lamp Life and Brightness - Projector Reviews
Feb 26, 2015 - There are still a number of 2000 hours at full power projector still on the... brighter, like projector Y, but Y just doesn't have the picture quality.".
Resetting Lamp Hours on a Sharp Projector - Spiceworks
Jun 12, 2011 - However, once you change the lamp the projector still won't turn on ...If it still doesn't work then there is some other problem with the projector.
How to Repair InFocus Projector Power Issue (LP290 ...
? 1:56
May 7, 2012 - Uploaded by zibodiz
A common problem with older InFocus LCD Projectors causes them to turn off at ... How to Repair InFocus Projector PowerIssue (LP290/LP280) ... How to Install a Bare Projector Lamp into your Projector - Duration: 4:05. by ..
Dec 14, 2015 | Multimedia Projectors
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
Nov 19, 2010 | Dell 1800MP Projector
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Is there any way to check the bulb life on a Sanyo PLC-XU30 projector? I know some projectors have an option on the menu screen which lets you know how long the bulb has left. Its just that i bought it off...
on my XU 55 the trick to read the lamp hours is to press and hold down the power button in about 20 seconds when the projector is turned on. there will come a window in the upper left corner that tells about total hours and lamp hours. the window will disappear quite fast, so one might need to do it twice.
Jul 28, 2009 | Sanyo PLC-XU30 LCD Projector
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
Lamp light
That light is there to tell you that the lamp is close to the end of its useful life. It simple monitors the amount of current that the lamp is drawing, so if the lamp stops drawing a preset amount of current, the lamp light will come on, indicating to you to order a new lamp so you have one when this lamp finaly burns out. Good Luck
Jun 07, 2007 | Philips bSure XG2 Brilliance Multimedia...
Philips bSure SV2 Brilliance Multimedia Projector Logo
46 people viewed this question
Top Philips Multimedia Projectors Experts
Lawrence Oravetz
Frank Russell
Frank Russell
Are you a Philips Multimedia Projector Expert? Answer questions, earn points and help others
