Can stop cranking. With compression figures that low, it will never start. Are you sure the figures are accurate? Throttle wide open when cranking up pressure? Compression has to be at least 100 psi for the spark to ignite the mixture.
If the belt broke while engine was running, and if it is an interference engine, you may have sustained some bent valves, internal damage to one or more cylinders, but not, I don't think, to all cylinders. I don't understand how you are getting such low compression on all cylinders Those figures sound like both head gaskets are failed, or the timing is way off.
Review your timing procedure and recheck compression. Something is definitely wrong. Hope you can figure it out. Good luck.
SOURCE: no compression
Dont worry to much the Millenia is a non-interference engine so the valves did not get bent. You just need to re-adjust the belt again in its proper position.
SOURCE: 2002 mazda poetege> correct timing mark alignment.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528019f906
there are other diagrams on that page if this is not the right one.
SOURCE: how to put a timing belt on a 2002 mazda millenia?
Sign up for the autozone online website and you can download the instructions there.
SOURCE: Are your cams in correct time as long as the
as long as it looks like this...
however, this only give you base engine timing
ignition timing is done with sensors and computers
Testimonial: "Great information."
