Question about Linksys Wireless-G WRT54G Router
Wrt54g - FTP flashed it after a failed upload attempt
WRT54G v 2.0d s/n CDF50DA13485
I uploaded v4.21.1 flash into the router via the UI and everything went fine...the flash came back successful...when i rebooted the UI was tabs, no lables, just the fields...i tried the 30 second reset joy...a buddy helped me ftp flash it and a apparently we reset it too it is literaly a brick...the Power light flashes quickly and the DMZ is in a slow (7 second) flash.
is there a factory refirb program, is there someone that i can send it to
I hate to just throw the thing away.
  • 132 Answers
You may try refalshing the firmware of the router again. Please do a hard reset on your router. To do that, press and hold the reset button of the router for about a 20 seconds. Keep holding the reset button and then unplug power from the router without releasing the reset button. Wait for about 15 seconds. After 15 seconds, power on the router and wait for about 15 seconds more then release the reset. Turn off the router and wait for a minute before turning it on. Observe if the power light is still blinking or not.
Then, check the IP address that the computer is obtaining. To do that, click on START>RUN then type CMD and then click OK. Once you're in the command prompt, type ipconfig/all then press ENTER. Look for the IP address it will give you.
If the computer does not obtain a valid IP address from the router, then you may need to assign a static IP address to the computer. To assign a static IP address to your computer: CONTROL PANEL>NETWORK CONNECTIONS. Right click on LOCAL AREA CONNECTIONS then click on PROPERTIES. Then look for Internet Protocol TCP/IP. Select it then click properties and then set it to Use the Following IP address. IP address will be set to Subnet Mask will be set to You may leave the default gateway and DNS servers blank. Click ok all the way out.
Open the command prompt again and then ping your router. Do the command, ping then press ENTER. Check if you will be able to receive replies or not.
If you received 4 replies from the ping then you may upgrade the firmware of the router. If not then the router is busted.
I believe, Linksys offers replacement for their in-warranty devices. You may verify from their customer service at 800 546 5797. They are using a certain tool which will detect the warranty of your router through its Serial number.
Hope this helps!
Posted on Nov 28, 2008
How to upload ready configuration file into the new switch?
yes you can upload configuration file on S5300 switch flash using serial connection. Please check below link. is an upgrade guide for deploying a system software. it shows you how to upload system software to the flash, the process is the same for configuration file.
it is possible to connect a laptop to the switch? Ethernet cable, configure ip addresses, enable ftp, configure ftp user and then upload to file to the switch via ethernet?
Apr 10, 2015 | Huawei Computers & Internet
List of the hidden webpages in the WRT54G 4.20.8 .. and higher
Following is the list of some hidden Web pagtes of WRT54G [ Firmware 4.20.8 or higher ] (list of MAC adresses) (RAM , Flash and processor) (Router statistics) (802.11 settings)
Courtesy :
on Mar 27, 2008 | Linksys Wireless-G WRT54G Router
Can't upload files or send emails via wifi with dgn1000 router
Has this ever worked and now something's changed, or have you never been able to make it work, please?
Nov 29, 2017 | NetGear DGN1000 Wireless Router
Have dsl connection, works fine. when linksys wrt54g router is correctly installed, no internet connection! ran diagnostic, all is fine, but no internet connection found-can't seem to upload new firmware...
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Turn the DSL modem on.
Wait for its lamps to settle-down to a consistent pattern.
Turn the Linksys router on.
Turn your computer on.
Wait for it to settle-down.
Click Start
Click Run
Type CMD
Press Enter
You should get output somewhat like: Default Gateway ....
if you have a connection between your router and your computer.
If you have that connection, you should be able to upload new firmware from your computer to the router.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
Wireless router disables fast access dsl
it may have corrupted firmware, try uploading newest firmware from manufacturer site and upload by wire trough GUI
Sep 13, 2009 | Linksys Wireless-G WRT54G Router
I think we bricked my WRT54G router
This router has a 3 year warranty from Linksys so if its still under warranty you can still have it replace from Linksys, you just need to contact Linksys tech support and they will have the router replace, this is their number 800-3267114.......
Nov 11, 2008 | Linksys Wireless-G WRT54G Router
Problems uploading files with WRT54G
It requires a port opened on your firewall to work.  Check with the software to find out which ones they need and then open the ports using the ip address of the router in internet explorer.  Type in your user id and password.  Go to Applications and gaming.  Go to port triggering.  Type in the application name on the first column and add the starting and ending port to the trigering range.
Sep 17, 2008 | Linksys Wireless-G WRT54G Router
Flash doesn't show on the website
Publish the HTML file from the flash. Upload both the HTML and SWF.
May 03, 2008 | Macromedia Flash MX
how are you pluged into the router? wireless or eathernet? wireless conections are not fast enough for these down loads. plug directly in to the router for down or uploading
Dec 29, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
205 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
