Question about Teac CD-P1250 CD Player
Are concrete slabs suitable for a stable floor?
I want to refurbish an old stable. It has an earth floor at the moment. As I can't afford to get concrete laid, so I was thinking of paving it. Is there any reason why well-laid concrete paving slabs wouldn't be suitable for a stable floor? I know that they must not be smooth (ie slippery).
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
So long as you level the floor and put at least 2 inches of cushion sand down they should be fine. If you don't use the cushion sand, there will be too many variables as far as movement. The if you tamp the pavers down, sweep sand into the cracks, and lightly wash it off, the sand acts as mortar, keeping the pavers from moving too much. Because pavers aren't typically reinforced, they are only as strong as the underlay, or substrate, so make sure you do a good job prepping and they will be fine.
Posted on May 27, 2009
What kind of detergent is suitable for washing concrete patio slabs during pressure washing
KARCHER MAKE A STONE CLEANING DETURGANT THAT WORKS WELL ON ALL TYPES OF CONCRETE.
Mar 13, 2016 | Karcher Garden
Is there a concrete floor sealant that eliminated moisture seeming through the concrete slab?
if you want to seal the surface a epoxy paint is good !
but if the water come from under the concrete slab only a hole with aggregates ( small rocks ) and a swamp pump works fine !
Oct 04, 2015 | Washing Machines
What best flooring for kitchen large dogs
Better Ceramic Floor Tiles where can easily clean.
Apr 13, 2015 | Building Materials
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
How do I fix a low spungy spot on a floating engineered floor?
Last night I posted a very lengthy answer to this from my phone ...I clicked post answer and it disappeared. So here I am on the lap top trying it again
I need to know if you have a wood subfloor or concrete slab ?
The wood subfloor typically allows you a crawl space under the house if you are on the first floor. Drill 1/4" holes into the subfloor and inject silicone under the void. This will dry and be soft and flexible and water proof. Use a 10 oz cartridge and a caulking gun.
Silicone is not an adhesive so it wont cause issues with the concept of a Floating Floor system.
The concrete slab gives no alternative other than taking the wood floor up and solving it by repairing the slab with a inexpensive floor patch depending on the severity and size. I can give detailed instructions on this as well...if you choose to do it yourself.
Let me know
Oct 14, 2014 | Millstead Hardwood Reducer: Oak Harvest...
I painted a section of my garage floor with a cup of paint 1/4c oil base acrylic mixed with 3/4 c water base latex...will it ever dry thoroughly? it is drying slowly and is really sticky. will I just have...
did you ever try to mix water with oil? what was the result? are you sure that you can cross the street without adult holding your hand?
unfortunately you need to remove all that paint, just drop few shovels of fine sand over, and scrape it... sand will adhere to the tp surface of the pain and will allow you to scrape it. after you scrape it off, use any degreaser or similar product to wash reminder off, leave it for few weeks to dry through and then in small patch try if it would accept latex pain, roll it very, very thinly and leave overnight, if it is dry (solid dry) after 24hrs and do not peel off, you can then use this paint on the rest of your garage floor.
now, i would advice strongly against painting garage floor with any paint except concrete paint (they are usually water based with strongly alcalic ph), and after that use concrete seal. this should give you long lasting surface, sealed from oils, dust, water and whatever contaminant you can imagine in the garage.
Sep 12, 2013 | Sherwin-Williams Best Look Latex Garage...
How to repair a water pipe leak under a concreat slab
Things to consider are cut and replace -1. Concrete saw the affected area replace and re-concrete (impact hammer is another option but a concrete saw is neater and you can control the cut better.. 2. You can bypass the pipe. 3. Dig under the slab - you obviously would need to be near an edge.
Jan 18, 2013 | Brett Plummer Android Apps
We live in a slab home. We have been noticing a order that smells like sewage. It is mainly coming from the floor heating vents in the kitchen and in the back laundry room. Is there a way to find out...
some where under your slab your sewer pipe has broken. most times you must cut away the concrete floor and explore for damaged pipes.
Jul 23, 2009 | Plumbing
Teac CD-P1250 CD Player Logo
328 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
